1967 Pontiac Firebird Parts
1974 Pontiac 4X-1H Heads, light surface rust, needs a good cleaning, ported and gasket matched. Bought them for my existing engine and bought a new block and moving in a different direction. Date codes F134 and F194 with an 10 number of 1H. $175.00
QA1 Tie Rod sleeve, new tie rod sleeve and jamb nuts, never used. $60.00 (shipping $10 extra) Used original 11 bolt water pump, D2, 188296, removed from a running engine, needs a good cleaning, worked as intended. $40 (shipping $20 extra) Used and original timing change and gears, removed from a running engine, needs a good cleaning, worked as intended. $10 (shipping $10 extra) Original oil pan bolts, they all need a good cleaning. $10 (shipping $8 extra) Original used head bolts. $10 (shipping $8 extra) Original 67 gas tank door, painted gray, spring works well. $20 (shipping $10 extra) Original Pontiac Firebird glove box door (primed gray) and hinge, minor pitting easy repair, great shape for the age. $25 (shipping $18 extra) Original 67 Pontiac Firebird glove box door (red) and hinge, has 3 small holes on front panel, needs work but is repairable. $10(shipping $18 extra) Original Pontiac Firebird engine hoist bracket. $5 (shipping $5 extra) For addition pictures, check out: https://southjersey.craigslist.org/p...816477039.html
IG: #67MoparBird (Follow my rebuild) 1967 Firebird 400 Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?' |
Located in Cherry Hill NJ
bump....
bump....
4X Heads, water pump, gas tank door, glove box door.....
bump
Bump...
67-68 Firebird Parts: 11 bolt water pump, gas tank door, glove box doors
bump
bump
bump...
Also have (2) cowl / vents panel, $30 each.
bump... Make me an offer...
