Old 06-21-2018, 10:18 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Early 65 Shield
Little known fact.
The first design 1965 Metal Shield (finger guard) was used in just the “first quarter of the 65 build, (9A, 10A, 11A) are the samples I have on file. Also the early 65 test cars show this first design.
The RH rear corner lip was “Flat”.
This would be for both style radiator cap holes. The 2bbl. and 4bbl. version and the Tri-power version.
Starting in late Nov. build, a design change was made. The RH rear corner lip was “Turned Down”. This carried through the 1967 year.
The thought I have was to prevent the sharp edge being close to the 65 upper radiator hose.
I wonder how many show judges are aware of this detail on early builds.
PS, if anyone has a nice original paint early design, I would be interested.
Thanks, Chris.
ID:	486035   Click image for larger version
ID:	486036   Click image for larger version
ID:	486037   Click image for larger version
Old 06-21-2018, 10:22 PM
694.1 694.1 is offline
Nah... bet the bent one was dropped
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 06-21-2018, 10:26 PM
60sstuff's Avatar
Originally Posted by 694.1 View Post
Nah... bet the bent was dropped
Huh ?
Old 06-22-2018, 03:40 PM
8LUG 8LUG is offline
Good info
Old 06-22-2018, 04:13 PM
Old Goat Racer's Avatar
From no less than the Empire State Building.
Everybody knows somthin.
Nobody knows everything !
Old 06-22-2018, 04:15 PM
An engineering correction ? Good call.
Old 06-22-2018, 04:17 PM
Then I had to go look at my repop.
It was dropped too.
Old 10-11-2019, 08:51 PM
60sstuff's Avatar
Default Another early 65 item
Just needed to look “up” for this early issue Safety Catch design.
It’s called a “STOP”, Hood Safety Catch.
1964 did not have this STOP, nor did the early 65.
Somewhere around the first quarter plus of the 65 build, Pontiac started installing this component.
It’s seen on the last three quarters of 65 build through 66/67 builds.
Learn something new again.
1) 1964
2) my early 65
3) later build 65
Next, MPC illustration #67.
Chris.
ID:	522006   Click image for larger version
ID:	522007   Click image for larger version
ID:	522008   Click image for larger version
ID:	522009   Click image for larger version
Old 10-12-2019, 01:02 AM
brut4s's Avatar
brut4s brut4s is offline
Talking
Mine was dropped too!
Old 10-17-2019, 01:17 PM
dld's Avatar
dld dld is offline
60sstuff
had a point taken at GTOAA convention for missing hardware. My car is a 12c BAL car
Old 10-17-2019, 01:29 PM
dld's Avatar
dld dld is offline
here is a pic of my car with the bent edge on fan finger guard. this supports your info. on hose interference
Old 10-19-2019, 09:07 AM
60sstuff's Avatar
Originally Posted by dld View Post
60sstuff
Don,
Just goes to show us that the judges make “mistakes”.
Your 65 is early enough that it did not have that “STOP” installed yet.
Therefore, you should not have lost a point!
There are about 5 to 6 items under the hood of an early 65 that differ from the later built 65’s.
All early test car articles, plus early Survivors will support this.
Judges do not know of these facts.
Chris.
Old 10-19-2019, 10:19 AM
Tom Vaught's Avatar
Boost Engineer
"Judges" do their best but most were not even born or were in Kindergarten when the cars were first built and sold.
Tom V.
Old 10-19-2019, 01:59 PM
60sstuff's Avatar
Tom V.
Tom,
Yes, I agree the “judges” do their best, and I don’t envy them.
It has nothing to do with when they were born.
The National events such as GTOAA have been going on for years and it would be nice to see a little more research on the correct factory components so guys like Don do not lose points for having “what is correct” on his car.
Chris.
Old 10-19-2019, 05:50 PM
dld's Avatar
dld dld is offline
Having my car at three GTOAA conventions and this year at POIC . I think the judging is overall great. There very tuned in to these cars. more so GTOAA . for good reason. there teams only do specific years 64 65 ..66 67 ..ect. and I have seen the same judges time after time . Scott Tiemann and his team have judged my car all three years
I really want them to be critical. I'm always willing to learn and make car better
problem is you don't see the score sheet unless judge points out the reason for his score. but for the most part they will listen to objection with a willingness to learn. especially if you do not get all crazy . i will say they are very thorough and most have been doing it for years. but unless you are on this forum 24-7 its tough to be a subject matter expert on these 64-65 years and the differences in hardware used along with running changes made through the year in four different assembly plants.
also as your car gets to a higher grade they look even harder it seems . but its all good . I would encourage anyone to build a car and have it judged
Don
Old 10-19-2019, 08:45 PM
Tom Vaught's Avatar
Boost Engineer
Don
And where did Scott Tiemann get his original knowledge from?
His dad bought a 1965 GTO which Scott still has.
He became an expert on the way the plant that built his dad"s 65 GTO put it together.
That does not necessarily make him an expert on the way that the other plants did their stuff except by looking at other original examples from those plants for a given production date. He has looked at a lot of other Plant builty cars (but not every one).
He is a very sharp GTO Guy and Judge but he is not the source for all 64-65 GTO knowledge. No one ever is.
I have personally known him for many years, been to his shop many times on my way across the state, etc.
Just saying. Not starting a urination contest. Judges can make mistakes, as was pointed out in earlier posts.
And it does have to do with how old they are. Keith Seymore actually worked in the Plants for many years, His Dad raced a Royal GTO campaigned out of Royal's dealership. He does not claim to be the wealth of all GTO knowledge though.
Tom V.
