Old 09-29-2019, 12:20 PM
davidgto davidgto is offline
Default clear coat
What was the earliest clear coat was used in the resto hobby or business. I have a 65 GTO that was repainted in 1975 and looks to be clear coat. Was this used at that early date? I am not a paint expert.
Old 09-29-2019, 03:56 PM
OG68 OG68 is offline
My 70 El Camino was repainted in '88 with a clear coat. Like you, I'm not an expert as to when they started.
2007 Cadillac SRX
Old 09-29-2019, 04:02 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
If it was done in 1975 its most likely lacquer clear..
________________________________________
65 GTO
owner since 84
original ca car
Old 09-29-2019, 05:00 PM
Default xxxxxxx
I wet sanded the trunk area and get no color on the sand paper or buffer.
Old 09-29-2019, 05:15 PM
MUSLCAH MUSLCAH is offline
My first encounter with a urethane clear coat over activated enamel was in 1978. I sprayed it on my 57 Chevy Wagon.....iam trying to remember the company.....it wasn’t one of the big players.Color International ..keep popping in my head....but I have inhaled a lot of paint fumes since then...so I could be wrong...but the 1978 year is correct.
Old 09-29-2019, 08:28 PM
While in the Navy, in 1978 I bought a Camaro. A sailor I worked with also had one and just had it repainted with urethane clearcoat.
Old 09-30-2019, 09:40 AM
Default xxxxxxxx
Is urethane clear coat a 2 stage process?
Old 09-30-2019, 10:00 AM
Like noted...you probably have Lacquer clear on your car. Take some 2000 grit and scuff a small spot...if the residue is white on the paper....you have clear....if the residue is the color of the car....no clear. Back in 1975 there were no urethane clears around to my knowledge.
Old 09-30-2019, 08:28 PM
Default xxxxxxxxxxx
Tried the 2000. White on the paper.
Old 09-30-2019, 09:02 PM
There’s your answer
Old 09-30-2019, 09:18 PM
400 4spd.'s Avatar
Is the car white?
Old 09-30-2019, 09:22 PM
Nightwatch blue. Really no color showing on paper or buffer.
Old 09-30-2019, 09:50 PM
400 4spd.'s Avatar
Great! If you do see blue on the paper or buffer it means shooting more blue over the cut through, followed with clear on the whole panel.
Not what you want............
Being shot so long ago the odds are a clear lacquer is what you're working with. MUCH thinner than a urethane clear, so proceed with great caution!
Old 10-01-2019, 12:57 PM
Thanks so much
