Old 12-07-2019, 12:53 PM
grivera's Avatar
grivera grivera is online now
So this one also has the BBC rod journals. Before I return, are there rod and piston combos available to make this work in a stroked 400 block?
Pics attached. Measurements in 40 degree garage with Harbor Freight dial caliper and depending on positioning the measurements for MJ and RJ's were wither at advertised size or a hair under.
ID:	526206   Click image for larger version
ID:	526207   Click image for larger version
ID:	526208   Click image for larger version
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 12-07-2019, 12:56 PM
grivera's Avatar
More pics
ID:	526210   Click image for larger version
ID:	526211   Click image for larger version
ID:	526212   Click image for larger version
Will Rivera
Old 12-07-2019, 12:58 PM
grivera's Avatar
Last batch
ID:	526219   Click image for larger version
ID:	526220   Click image for larger version
ID:	526221   Click image for larger version
Will Rivera
Old 12-07-2019, 02:21 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Originally Posted by grivera View Post
Last batch
Check it for straightness. It's really a better deal that they are BBC rod journals because there are many more affordable BBC rods and bearings available.
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 12-07-2019, 03:00 PM
mgarblik mgarblik is offline
Question: Do the Molnar crankshafts have that same , Eagle style"winking eyeball" oil feed holes? That design is just wrong in so many ways. Over 6000 RPM your into cavitation and oil starvation, especially with the Pontiac marginal oil system. I will soon be in the market for a forged crankshaft, but personally won't use one with that style feed. Factory chamfered oil inlets would be better. It must be much less expensive to just hog those big divots into the shaft rather than create a nice smooth scoop. Here are some pics of proper oil inlets.
ID:	526236   Click image for larger version
Old 12-07-2019, 03:40 PM
Mike Davis's Avatar
There are a lot of piston /rod combos that will work with the 2.200 mains. Depending on budget a set of Scat or Eagle H beams and a Icon or Ross piston would work well.
https://uempistons.com/series-1643-i...7-1-ic937.html
I personally like the 2.200 journal like Randy stated, a lot more choices in bearings and rods.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 12-07-2019, 03:42 PM
grivera's Avatar
I assume I have to take it to a machine shop to have a check for straightness?
Will Rivera
Old 12-07-2019, 03:44 PM
Mike Davis's Avatar
Yes, but that should be done with any crankshaft no matter what brand or material. I have seen factory cranks bent and high dollar cranks bent...…..
Old 12-07-2019, 03:56 PM
Stan Weiss's Avatar
Did I do it wrong for all of those years? I would put a bearing in #1 and #5. Lay crank in and put dial indicator on #3 main and rotate the crank.
Stan
Pontiac Pump Gas List
Old 12-07-2019, 03:57 PM
Mike,
Would 3/4 or full groove mains be enough to overcome that?
Clay
Old 12-07-2019, 04:03 PM
Mike Davis's Avatar
Stan
Well that is how I check, but also check journal 2 and 4.
Old 12-07-2019, 04:12 PM
Originally Posted by "QUICK-SILVER" View Post
Mike,
Clay
I honestly don't know. I just don't like the way those oil hole areas are finished. Personal preference, I guess. At lower engine speeds, they are probably fine. I have seen heavily distressed bearings in Chevy and Pontiac engines that have utilized that style oil passage. If you think about it, bearing support area is taken away from grinding a giant divot across the journal. Then they just polish the surface and call it done. I think much more care and detail needs to go into that area of the engine. Even the factory just drilled the holes, broke the edges and then polished. I have been overall impressed with the Molnar rods and was just curious how they finished their cranks. Interesting side note: I have been all over the internet looking for a single good picture of the oil holes in a Molnar crankshaft. Not a single good picture, including the Molnar website. I will talk to Tom Molnar and look in person at PRI next week. That's the beauty of PRI.
Old 12-07-2019, 04:38 PM
Here you go! Molnar Crank
ID:	526244   Click image for larger version
ID:	526245   Click image for larger version
Randy Repp
Old 12-07-2019, 04:41 PM
Default Hold On
Mike,
Clay
Got confused there after looking at Mike's pics. Got pics mixed up between the rod journal pic and main pic.
So what do the feed holes in the mains look like on the OP's crank?
Clay
Old 12-07-2019, 05:12 PM
Clay
The Speedmaster cranks have a small divot on both sides of the main feed hole like you ground it with a bit or cartridge roll across the hole. Very old school but not unrepairable.
Randy Repp
Old 12-07-2019, 05:35 PM
Hooter's Avatar
Hooter Hooter is offline
My 4.375 Molnar crank was like the pics Randy posted.
67 Bonneville ragtop
Old 12-07-2019, 06:00 PM
grivera's Avatar
If bent, is a machine shop able to straighten?
Will Rivera
  #38
Old 12-07-2019, 08:10 PM
Mike Davis's Avatar
It can be done if they are a good shop.
I would not sweat it right now until you have it checked. The oil holes are minor and unless it is a max effort it won't matter. I have a crank that the oil holes look like that that was run for years at over 7K RPM. Just put a good oil pump in it and watch the clearances.
  #39
Old 12-07-2019, 10:15 PM
Thank you for the pics of the Molnar crank. It's lovely IMO. If I was buying a forged crank, that oil feed design and finish is what I would be looking for in a higher RPM component. I know the Molnar cranks are off shore like all the others, but that piece is clearly a nicer, more finished piece than anything I have seen from Eagle, Ohio Crankshaft and some of the other vendors. Look forward to talking to Tom at PRI. My next personal build will be a mild solid roller cam engine that I want to feel safe shifting at 7000-7500 RPM. So a good oiling system and delivery to the bearings is important.
