Old 08-02-2010, 12:39 PM
firebirdmi firebirdmi is offline
Default remove front clip as one piece
I'm getting close to finishing up the bodywork on my '68 firebird project and have everything on the front clip lined up really well. Question is, can I remove the front clip as one piece (excluding hood and cowl of course) by just removing the two front tires or do I have to modify anything? Will the front suspension need to be removed to clear the inner wheel wells?
Car has manual brakes and auto trans.
Old 08-02-2010, 02:34 PM
boater bill's Avatar
boater bill boater bill is offline
If you remove the tires, the front clip can be removed as one piece. Unbolt the wheel housings at the rear where they bolt up to the frame, often forgotten to do.
Good luck.
Old 08-02-2010, 10:52 PM
Cammer-6 Cammer-6 is offline
they call it a doghouse
I would call it a chicken coop(Fire Chicken)
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-03-2010, 09:00 AM
steveK steveK is offline
I'd like to see that cowl removed as part of that front clip without using a sawzall ?!
Steve Karew
Old 08-03-2010, 07:20 PM
Thanks for the info. Looks like I'll need to gather 2 - 3 friends for help as well as case of beer (served afterwards)
Old 08-04-2010, 07:10 AM
Maybe get 2 cases, the other one is for putting it back on. Use caution though...serve only when job is completed. good luck!
Steve Karew
Thread Tools
Display Modes
