Old 10-03-2019, 10:50 PM
MUSLCAH MUSLCAH is offline
Default Looking for an Inch.....
What’s out there to raise my 67 GTO rear stance up just 1 inch ?? Not going bags and has 4 year old springs in it. Thanks for any help
Old 10-04-2019, 12:53 AM
Scott65's Avatar
Scott65 Scott65 is offline
What kind of shape are the rubber isolators in? If they're worn, or absent, maybe you'd gain a little there.
Old 10-04-2019, 05:41 AM
Geoff Geoff is offline
Summit have spacers for fronts, not sure about rears.
The Following User Says Thank You to Geoff For This Useful Post:
Old 10-04-2019, 06:49 AM
AG's Avatar
AG AG is offline
You can buy spacers for the rear and get it exactly where you want it.
Old 10-04-2019, 07:33 AM
younggto younggto is offline
Eaton Detroit Spring sells just a spring. They’re not cheap but I’ve had great luck with them.
Old 10-04-2019, 08:16 AM
The Champ's Avatar
I had Coil Spring Specialties make a custom set of springs for my '64. I asked for .75" over stock (I had 1 year old PY rear springs at the time). After installing the springs - the rear end was raised exactly .75". IIRC, the springs were about $25 more than the "correct" springs at the time.
Old 10-04-2019, 08:21 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Summit has spacers that go between the bottom of the rear spring and the spring perch (?) on the rear. Been using them for 10+yrs
Chris D
Old 10-04-2019, 11:53 AM
JohnnyAction JohnnyAction is offline
Hello, I had the same problem with a 1965 GTO. I installed a set of MOOG # 6197 springs that raised the ride height 1 1/8 inch and gave a slightly firmer ride. These springs are listed for chevelle applications and are slightly thicker wire diameter, but worked perfect in this application. Replace rubber spring isolators with springs. John
Old 10-04-2019, 02:35 PM
george kujanski's Avatar
I have the cylindrical spacers that mount on the bottom spring perch, effectively making the spring perch higher. Simple, no change to spring rate, etc.
George
Old 10-04-2019, 03:12 PM
I ended up gong with the bags myself, but I was considering these at first.
https://www.summitracing.com/parts/g...7/make/pontiac
Old 10-04-2019, 03:53 PM
Johnny99's Avatar
Johnny99 Johnny99 is offline
The 6197 will give you what you are looking for. $54 at amazon
I tried them for a few days on a 65 but replaced them with a new set of 5237's as she sat too high for the small rubber I've got on the back.
NOT a GTO. 1965 LeMans 455
Old 10-05-2019, 10:00 AM
tjs72lemans tjs72lemans is offline
I agree with the spring spacers in bottom. Cheap and easy to install without changing spring rate.
Old 10-05-2019, 12:13 PM
I did the same on my 65 GTO 6197 springs picked it up over the MOOG GTO replacement spring-which even the new one seemed too low.
Global West has different front spring spacers that fit in the control arm.
Old 10-05-2019, 02:36 PM
rohrt rohrt is offline
My 64 has a some kind of helper spring shocks on the back. I bought the car that way so I don't know who sells them but just another possible option.
