#41
Nice article. Matches a lot of the info I received in a couple of Fuels and Lubes Engineering classes years ago.
Quite a bit more info on the different anti detonation tools out there like the water meth kits. Thanks. Tom V.
#42
Typical race fuel dealer propaganda about avgas.
Less said,,,,,,,, Less mended. |
#43
What most don't understand is you have to add a Pitot Tube to actually measure how much better the car runs on AV gas. If you also add a Altimeter and reset 0 at +2500ft you should not have any problems because the car thinks it's at 2500 feet instead of sea level.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
#44
OP, what has transpired with the builder since you last posted?
The More People I Meet, The More I Love My Dogs! |
#45
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
#46
Street guys need to be around 2500ft, also need carb heat on and the mixture set rich so not to freeze up.
#47
BULL DINKY!
#48
Pretty much. We ran 100LL in all our fuel trucks. It had to be nearly zero degrees before there were any cold starting problems.
#49
#50
Sorry I've been out. Shoulder surgery OUCH!
He said there were 6 valves that were sticking. after I removed the valve debris and reinstalled the head I rolled it over several times and all valves seemed to work just fine. I've decided to rebuild my old but not original engine. He'll pay me back one way or another. You guys are a wealth of information. Thank Yall |
#51
P.S. I had to take the car to his shop shortly after the install because the internal dipstick tube was wrong (couldn't check the oil). At that time he noticed the pushrods were hitting the head and installed longer ones. Could this help in your diagnoses ?
#52
Find a new engine builder, this guy has no idea what he is doing.
#53
Pushrods hitting the heads? WTF does that even mean?
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#54
X 2!
#55
I was wondering the same thing...1.65 ratio rockers in a head that hasn't had the holes elongated? Even so.... longer pushrods?
Greg Reid Palmetto, Georgia |
#56
Talked to a lawyer today.. Damnit! 1 expert witness and a lawyer eat up the cost of a n ew motor on day 1. Needs an ass whoopin
#57
Where are you located at? I have two expert engine builders in SC that I found thru extreme research. One is Carolina machine engine www.cmengines.com the other is wayne Skess at Greenwood autoparts.
#58
Bottom line is, the jackleg builder is taking premium money and blaming his fu&kup`s on fuel that he knows nothing about.
#59
How much does a full page article in the local newspaper cost? There is more than one way to split this atom. Let him choose between making it right and you ruining his business.
#60
