67 block really that good
I know where there are three 67 GTO’s sitting in the woods complete hoods and doors closed been there for decades. I am quasi friends with the owner so I called him and asked him if he still had them. He said he did but that Mother Earth was reclaiming them and the only thing worth any money was the engine and trans. He seemed a little reluctant at selling as he has Pontiac projects of his own but I asked him what he would take for one. He said 1500 for a complete down to the ac compressor 67 400 from one of the GTO and I had to pull it. Are they really that scarce/valuable?
Why oh why do people let this happen to these old cars.
Only if the date and other codes match up for another vehicle (other than partial VIN) and you the buyer have a thing for code correct parts.
1971 Pontiac Trans Am Cameo White 1968 Firebird 400 coupe, Verdoro Green w/black vinyl top 1968 Firebird 400 convertible, Verdoro Green w/black top 1970 Buick Skylark Custom convertible(driver) Fire Red 1972 Buick GS 455 Stage 1 Royal Blue |
The 67 "GTO" block would not be the hot ticket for real performance as it would have two bolt mains but drilled for 4 bolt mains. Weaker deal vs the 67 2-barrel type engine with solid not drilled main webs and regular 2 bolt main caps.
A 67 4-bolt main drilled block has really good cylinder support and main web support EXCEPT when they drilled those extra holes for the 4-bolt mains and put 2 bolt caps on the block. Hot set-up is add SPLAYED bolt 4-bolt main caps to a 2 bolt main 67 2-barrel block. Tom V.
Sounds like he’s not ready to sell....
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
If you are going to spend $1500.00 and want something good for performance, offer it to this guy > https://www.ebay.com/itm/CAL-1969-PO...5Z8WiO&vxp=mtr
You'll thank me later. |
Interesting. Hadn't thought of this idea before...
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
That was the way Marty Palbykin's 1967 406 engine was done. Good Splayed "PRO GRAM STEEL CAPS" added to that block. 1600 + HP for 3 years and the car weighed 2885 lbs and ran over 200 mph with Cast Iron Heads and Factory Original 67 2-bolt Main Block.(before caps added)
Tom V.
If I had to guess, that started around 69/70? |
None of my 67 blocks had been drilled or tapped. I did have a late 69 and a 1970 block that was.
$1500 for possible good engine+splayed main caps/hardware etc= purchase a IA II block.
I thought you already had a motor?
No way in hell am I paying 1500 for something laying in a rotting car that needs a complete rebuild. I just sold a board member a darn good running 455/6x4/performer/qjet/hei engine for $1500 bucks. Its old and mild but ran great. That guy is trying to take you for a ride.
I paid $75 bucks for a complete 67 2bbr engine from a guy on here about 5 years ago. Sold the timing cover and crank, scrapped the heads, and just about everything else and made money on the deal keeping the block. You should be able to find a non 557 400 for a few hundred bucks and do the same. There is nothing magical about a 67 400
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
I used an IAII block.....not at all concerned with originality.....plan for some machine work in the budget...but you would need to do that anyway. Just my 2 cents...
1500 is crazy money for a rusty 400 block and heads. Everything but the bare castings will go in the trash. You can usually find bare blocks from $200-500, and i wouldn't pay more than $300 for something that wasn't STD bore and either magged or guaranteed to pass mag. Locally there is a 455 block that needs two sleeves, and the guy wants $600 for it. There is a mismatched 400 and a stock 428 on the local CL for $1800 and $1900 respectively. These guys either live in fantasy island or its sucker bait.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 12-28-2017 at 08:59 PM. |
Except that a non-drilled 2-Bolt Main 67 block with cast iron heads was strong enough to run 6 second times at high boost for 3 years without breaking vs other 400 blocks (like the 557) that would kick its guts out at 500 HP in most Trans AMs.
Tom V.
I find that often times less information listed leads to the best deals on car/engine parts on craigslist.
So my 67 2bbl splayed main .030 over block 433 is good for 6 second runs....good to know. No one here is trying to do that. Just about any non 557 2 bolt 400 block is going to take 600hp right? That covers 99% of everyone in the hobby. My point stands.
Did I make a wrong turn?Is this the street or race section?Tom
