Closed Thread
Old 01-28-2015, 08:58 AM
Default A question about date codes
My 69 350 HO block (not original to the car) has a date code of Oct 28 (J028). I have 3 sets of #48 heads and the best pair has a date code of early December (L038), but I do have a set of heads built in October. The car was delivered in late January of 69. Is the date code on the block close enough to be considered "numbers matching"? Would I be better off having the head date codes match the block, or should I use the early December heads?
For those out there with numbers matching cars, what's the time frame for you date codes WRT the build date?
Old 01-28-2015, 07:58 PM
jinxd68 jinxd68 is offline
the date you have on your block is October 2nd 1968. i've seen in the industry an "acceptable" range as 3 months prior to build date of car. If it was me personally i would use the October heads to match the block. My numbers matching 400 68 bird was build 12D, December 4th week. the block has a casting date of L207(december 20 67), intake L137 and heads L017. Not sure if that answers your question or not but thats what i have seen.
Old 01-28-2015, 10:15 PM
Thanks for the info. This is the block:
Is the number over the block code part of the car's VIN?
Old 01-28-2015, 10:23 PM
WDCreech's Avatar
WDCreech WDCreech is offline
No! That is an engine unit number.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 01-28-2015, 10:35 PM
There should be a partial VIN down lower next to the timing cover, about where the radiator hose outlet on cover is.
It'll look something like 29U1xxxxx with the 'U' depends on the plant car is made at.
Old 01-30-2015, 12:00 AM
Thanks.
Old 02-13-2015, 01:28 AM
6d7gto 6d7gto is offline
Engine should be earlier than the car's build date. Most engine components like the heads should be earlier than the engine casting date. Too early is better than too late in my opinion.
Old 02-13-2015, 08:30 AM
68tpls400 68tpls400 is offline
69 350 HO block (not original to the car) Is the date code on the block close enough to be considered "numbers matching"?
Please don't confuse 'numbers matching' with 'numbers correct'.
If you do not have the 'born with' block, you will never have a 'numbers matching' drivetrain.
May be semantics to some, but IMHO correct.
Old 02-13-2015, 09:21 AM
The Boss's Avatar
The Boss The Boss is offline
Date range depends upon where your car was built. The engines were ALL assembled in Pontiac MI and then shipped by train to the assembly plants. If your car was built in Freemont CA or Atlanta GA then the lead time would be longer.
And go racin' in the street.
Old 02-17-2015, 11:23 PM
I'm not sure where you came up with "numbers correct" to define this, but numbers matching means the part numbers and date codes are correct for the car. A "born with" drivetrain means the engine is the one the car came with. My "WN" block is a correct "numbers matching" block for this car. If it were coded for a Lemans, it may be exactly the same, but not numbers matching for the car.
Old 02-18-2015, 06:03 AM
wovenweb's Avatar
wovenweb wovenweb is offline
There is no definitive definition of numbers matching. One could point to the EUN on the billing history card(the source of record for your vehicle)for your car and say that for it to be numbers matching requires the block in your car to be the one listed, to match. Anything less than this = not original and thus of lesser value in some people's eyes.
1971 Pontiac Trans Am Cameo White
1968 Firebird 400 convertible, Verdoro Green w/black top
1970 Buick Skylark Custom convertible(driver) Fire Red
Old 02-18-2015, 06:08 AM
wovenweb's Avatar
It is 4 AM my time zone and I haven't slept well, so am cranky and picky...but since we are in the '67-'69 Firebird section, I do want to point out that Firebirds weren't assembled in Fremont or Atlanta. Van Nuys, Norwood, Lordstown and apparently Antwerp, yes.
I really should go back to bed and not post.
Old 02-18-2015, 07:59 AM
The Boss's Avatar
Excellent point - not much distance from Pontiac, MI to Lordstown or Norwood but the point holds for Van Nuys regardless of the plants I named to make it.
Go get some sleep!
Old 02-18-2015, 09:28 PM
I think there is a definitive definition to "numbers matching". The car was built with parts. Those parts have date codes and part numbers. If you have a 69 Ram Air IV car with a correctly coded block, it's numbers matching. If it's a SR block, that could have been done by the dealers, so I would also consider this on the side of "numbers matching," because it implies the history of the car included maintenance which required the block be replaced.
1969 was a long ass time ago. Not some, but most of these cars lost their engine at some point. I still have the "born with" transmission for my 69 350HO automatic convertible, but the engine in it now is a 68 Catalina 400... it's not numbers matching. If the inverse were true, and I had the correct engine, but a wrongly coded transmission (turbo 400), I could say it was mostly numbers matching, but that requires opinion to decipher.
The tall and short of it is this... if you buy a car with a close drivetrain, it's worth more money. If it has the "born with" drivetrain, it's worth even more money. If it's a hot rod with a Chevy 350 but looks mostly stock, it's worth less; that's the bottom line. To imply the block has to be original to the car to make the claim it's "numbers matching" is probably the opinion of someone fortunate to have the "born with" drivetrain that includes to correct VIN. This isn't semantics IMO... parts are parts and they have numbers.
Old 02-19-2015, 07:38 AM
wovenweb's Avatar
I would note that your definition benefits you which makes it suspect. I'm could be 100% wrong but I'm not aware of any large body (ISCA for example) that has waded into this debate. You may define it how you want but again, creating or agreeing to a definition that benefits your "case" and potentially financially is suspect.
Irrelevant. Also I would note that the whole point of the numbers matching definition is to exclude, not include vehicles and to a large degree denote those that deserve a higher value due to that exclusiveness. So, like some I prefer the more exclusive definition.
I've only been in the "hobby" for 10 or so years, so the more wise and learned would have better perspective, but I don't recall the "born with" phrase until the last few years. Not that this is necessarily bad, but I see it as an attempt to carve out a more expansive definition of numbers matching. I'll stick to the one where the "born with" drive line is still intact. Yes, that is preferable to a SR with dealer replacement documentation which in my book wouldn't be numbers matching.
Agree with this 100%
Second time in a month where the word fortunate has been used in reply to one of my posts. I'm not that fortunate, I'm a strict constructionist who doesn't wallow in the past about decisions I've had to make. As far as the semantics portion, it is and it isn't. The block on your engine has an EUN, it doesn't match what was produced on your Billing History Card from the factory. The numbers don't match.
PS An article from a couple years back where the author laments the degrading of the meaning of numbers matching...
http://www.newsday.com/classifieds/c...sals-1.6154213
Old 02-19-2015, 07:43 AM
wovenweb's Avatar
Go get some sleep!
Yes, I agree with your point 100%, I'm most curious about the Antwerp date codes. Since they could have handled the assemblage of the parts prior to shipping in several way(collect all parts at say the Lordstown plant, put it into a container there then ship to outbound port, etc.) Or did they use Chevy engines like those that were assembled in Canada? Did they use Chevy engines for those assembled in Canada?
Old 02-19-2015, 07:49 AM
The Boss's Avatar
It's not semantics, and we're not implying anything here. By definition, the car HAS to have the original, born with block to even hope to use the term Numbers Matching when you describe the car. Any block, SR, non original but correctly coded, or incorrectly coded and it is not. That's it, end of story.
Old 02-19-2015, 10:32 AM
68bird400HO's Avatar
Agree. I have been in this hobby over 30 years. In all those years the term "Numbers Matching" has always meant that the vin #s on the block and tranny MATCH that of the car (or the EUN matches that on the billing card). It seems in the last 5 years or so the term "born with" has emerged as the new "numbers matching" as the latter seems to have lost it true meaning due to unscrupulous dealers, flippers, sellers, and auction houses. All I can say is, if I spend the time to drive to look at an advertised "numbers matching" car, I better see matching vins. As far as values, it is either VIN number matching, or it isn't. Engine and date code correct would be better than not. As far as the dealer warranty replacement excuse, everybody is using that now too. For me, I would need to see the paperwork showing that and I still would value it a little lower than a true VIN number matching car.
As far as date ranges, it sound like you are fine. I think the heads should be dated pretty close to the block. The build plant matters but so does the rarity of the car. My 400HOs VIN number matching motor is 6 months earlier than the car's build.
Old 02-19-2015, 10:59 AM
Date codes in like the engine date codes and body parts?
Or the 'build date' on the tag?
I believe the engines were Pontiac in Belgium cars.
All the parts and pieces were put in a big box and then shipped to New York port then shipped to Belgium.
They had a plant that assembled them there.
Then probably shipped to a dealer there for sale?
Old 02-19-2015, 12:01 PM
Keith Seymore's Avatar
Well said.
On the other end of the spectrum the cylinder head and engine block casting dates in my Pontiac built '65 GTO precede the car's final completion date by 9 days.
K
'63 LeMans Convertible
'63 Grand Prix
Closed Thread
