#121
Old 05-09-2024, 08:20 AM
roger1's Avatar
roger1 roger1 is offline
What a hassle.
I have the Comps on mine and so far they seem OK. They were NIB and came with the car when I bought it. I used them but was leery and still am. I don't know if the machine shop I had assemble the engine enlarged the holes or not.
Sometimes I wonder if the benefit over stock is really worth a risk. I've read that the benefits are very, very small.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #122
Old 05-09-2024, 11:03 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Is it actually the hole closer or is it because the slot/fulcrum area is larger? Curious.
I know many have had issues with the roller-tip only rockers, be it PRW or Comp, maybe it's inherent?
Were the pushrod holes enlarged? Generally, I advise to enlarge the holes when the heads are off as SOP, to avoid problems like these, regardless of cam/rockers used. But it is what it is at this point.
Glad you figured it out and know how frustrating things like this can be.
The pushrod holes were not enlarged. Ive never had problems with 1.5 rockers and the stock size holes and that's with some big cams Ive messed with in the past. Im thinking the ones I have are 1.65 and were mislabeled. Its hard to tell from the pics but the pushrod cup is much closer to the rocker stud than the stock rocker arms.
  #123
Old 05-09-2024, 01:15 PM
Is there a witness mark in the hole? I wonder if it's actually hitting the body/fulcrum area and not the hole? Maybe the pushrod is too long for the PRW rockers?
I'm just trying to understand where the problem is, I've not heard of it before specifically with PRW rockers. Not saying it isn't, just don't want a bad rap on a product and cause people to abandon a potential brand/product if not warranted.
So the general rule of thumb is once you go over .469 lift, or switch to 1.65s, it's possible to have contact in the hole. Both having roughly the same effect.
A lot of early aftermarket offerings for Pontiac cams all kept lift below .469 or added notes to verify hole & retainer clearances.
And yeah, can't tell by the pic, which is why I am asking. I'm sure you looked hard at it and bet it's obvious in person. Just never heard this with PRW rockers.
  #124
Old 05-09-2024, 03:23 PM
Im using a Summit 2802 cam. Only the intakes were hitting and the lift is only .466 on the intake side. Also there was a very slight witness mark on the pushrod. I didn't run it long like that. The stock rockers moved the pushrod way away from any contact with the hole.
  #125
Old 05-09-2024, 04:03 PM
.466 is very close to the .469 mark, and a pushrod length diff could have made the difference. (rocker causing pushrod length discrepancy) .
Even with the stamped rockers, in certain circumstances you may still have inference.
  #126
Old 05-17-2024, 02:36 PM
More fun. The blower motor wont come on. Checked the feed to the master switch (brown wire) and there is no power going to it. Checked the fuse box and I got power to both sides of the fuse. I took apart the fuse box and did a continuity test on the feed wire and it shows an open. This is a brand new harness from Ames made by M&H. Im debating running a bypass wire to the master switch or getting another new harness. What do you guys think? The harness was bought over a year ago so Im sure the warranty is no longer good.
  #127
Old 05-17-2024, 06:56 PM
roger1's Avatar
Me, I would find where the open is and the reason for it and fix it there. I have a Power Probe II which makes it easier to trace stuff like this. If I couldn't find it with that, I'd purchase the Power Probe ECT3000 circuit tester. That is tool I've wanted for a very long time anyway.
The Following User Says Thank You to roger1 For This Useful Post:
  #128
Old 05-18-2024, 02:00 PM
Well I got most of it fixed. Apparently there are 2 schematics for the 70. I was looking at the wrong one of course. One showed a direct feed to the master switch and the other showed it going to a connector. Mine was the one going to a connector and it wasn't hooked up. Problem solved. Now I have to figure out why the high speed on the fan doesn't work. Ive got the 12 volt feed line from the alternator hooked up and the fuse is in place.
  #129
Old 06-03-2024, 05:46 PM
High speed blower working now. Replaced high speed relay on firewall.
I ordered a parallel flow condenser from Classic Auto Air. The first one they sent was too warped to use. Sent it back. They sent me a another one and it didn't fit. had to modify and shim the brackets to make it fit.
ID:	634693   Click image for larger version
  #130
Old 06-24-2024, 03:07 PM
Its starting to look like a car finally. Im happy with the cars stance. Slightly lowered but not slammed.
ID:	635825   Click image for larger version
The Following 2 Users Say Thank You to Bruce Meyer For This Useful Post:
  #131
Old 06-29-2024, 10:17 AM
Tim Corcoran's Avatar
That is going to be one sweet GTO when your done and you couldn't have picked a better color. Those pictures are pretty dark. You might try turning on the flash next time.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
  #132
Old 06-29-2024, 11:07 AM
Looking good.
Auto-leveled the pics:
(made less shadows/darkness)
ID:	636074   Click image for larger version
  #133
Old 07-03-2024, 01:30 PM
The old T3 headlights tested good so I cleaned them up and put them back in. Even though they are 50 years old I trust them more than anything new sold nowadays.
ID:	636269   Click image for larger version
  #134
Old 08-15-2024, 06:08 PM
Im getting ready to put the decals on. I cant read the dimensions on this placement guide. Does anybody know them?
  #135
Old 08-17-2024, 11:57 AM
Its done. Almost. The stock hood hinges are too sloppy so I ordered new ones from Ames. I cracked one of the turn signal lenses so I have those on order too. As far as the fender decals I just guessed. I went on google and searched 70 GTO pics and saw that almost all were in a different positions.
The Following User Says Thank You to Bruce Meyer For This Useful Post:
  #136
Old 08-17-2024, 12:03 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks fantastic!!!!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60
The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60'
The Following User Says Thank You to OCMDGTO For This Useful Post:
