Old 06-04-2022, 02:46 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default 61-62 Temest transaxle pan tube leak
Any tips on sealing up the pan tube? Mine only leaks from this area.
Old 08-25-2024, 04:01 PM
Where the tube filler meets the pan I mean. It's leaking from there. On my '62 two-speed auto.
Old 08-26-2024, 08:47 AM
cleveweld's Avatar
cleveweld cleveweld is offline
Default Tube leak
Hey Chris, The dipstick/filler tube is a compression fitting basically like a large brake line. Tightening down the nut should seal it unless there is some sort of damage to the tube or pan. Try to snug it a little tighter. If it still leaks you could remove the tube to check mating surfaces. Greg
Old 08-26-2024, 11:59 AM
That is very helpful,, thanks Greg. I suppose this should be written in the shop manual but I didn't find it. Will tighten more, and see if that helps. A nut this size can probably take 45-50ft/lbs.
