How To Remove the Dash Pad & Instrument Panel?
Looked through the Fisher body manual and don't see much help there. How big a deal is it to remove the dash pad and instrument cluster from a 67 Catalina? Special tools needed?
Found a YouTube video on a 66 - similar?
Mark Las Cruces NM ___________________________ Current Project: '67 Catalina Convertible 400 4-spd |
I did it , big tip is front seat out , dash pad first,
Good luck, need help to remove dash . Good luck John L. Sent from my SM-A426B using Tapatalk
Very simple and I didn't remove the front seat. Remove the pad 1st.
I guess my specific questions are:
- any hidden fasteners on the dash pad? I see 7 or 8 screws underneath the lip that are easy to get to. On the '66 video he had to go in under the cowl to reach a hidden fastener... any here? - Once the dash pad is off, can you reach all fasteners that hold the instrument panel in?
Dash removal
How did you do on this? I’m doing the same thing removal dash 67 Catalina convertible
How did you do??? I got same issue have fisher manual no help there
There are 2 clip ins where the dash wraps down on the ends, have to be careful where you can wedge a big flat screw driver between the metal lower dash and top dash. Once you pop out the ends, also remember to remove 7 or 8 screws under the dash lip.
------------------------------------------------------------ 1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles 1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles 1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles 1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles |
Thanks for that. I’m doing a full re wire on this old convertible. Getting dash out is a must. I appreciate the response. It’s a big undertaking but I’ll get it.
Thread Tools | |
Display Modes | |
