Old 02-18-2014, 07:08 PM
stone7777's Avatar
stone7777 stone7777 is offline
Default Help identify external regualtor for a new engine harness
Help!
I am ordering a new engine harness for my 67 GTO project from Ames.
I have a 1976 Trans Am Engine in my car.
So, I have a HEI distributor.
Ames needs to know if I have a internal or external regulator.
I assume its internal .
I know, I know, its the wrong engine for the car. But I want to get it back on the road this summer.
Advice welcome.
Old 02-18-2014, 07:15 PM
54nomore's Avatar
54nomore 54nomore is offline
Alternator plug style:
square plug with this layout (I I)...external
flat rectangular plug with this layout (- -)...internal
Old 02-18-2014, 07:24 PM
stone7777's Avatar
I have taken a picture of the distributor and the alternator that came with the engine.
Helpful?
Name:	2 18 037.jpg
ID:	353516   Click image for larger version
Name:	2 18 039.jpg
Old 02-18-2014, 07:28 PM
54nomore's Avatar
That is and internally regulated alternator, sir.
The Following User Says Thank You to 54nomore For This Useful Post:
Old 02-18-2014, 07:34 PM
54nomore's Avatar
FWIW, your '67 should use and external regulator. Pontiac went to internal starting with the 1970 model year, if I remember correctly.
Old 02-18-2014, 07:41 PM
stone7777's Avatar
So
From your description and the pictures provided.
It looks like internal.
Ames will custom make a engine harness to fit the 67 dash harness and accommodate a HEI distributor.
Old 02-18-2014, 08:21 PM
54nomore's Avatar
I just realized I typed AND instead of AN in two consecutive posts, hopefully you got my meaning
Old 02-18-2014, 09:05 PM
Joel Koontz Joel Koontz is offline
The alternator does appear to have an internal regulator and if you are not concerned about originality, I would definitely recommend using an internal regulator alternator. I think they are generally much more reliable than the external regulators.
The Following 2 Users Say Thank You to Joel Koontz For This Useful Post:
Old 02-19-2014, 03:49 AM
Schurkey Schurkey is offline
...and internally-regulated alternators put out more power at idle/low speed.
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 02-19-2014, 11:52 AM
george kujanski's Avatar
Not meaning to be picky, but to qualify what has been said so far, there are OEM internally-regulated alts that have more output than the OEM 10DN alts (externally regulated), so if you will need more output, especially at low RPM, such as for electric fans, stereo amps, might as well go with the internally reg alt like the one you have. IIRC the 10DN OEM alts topped out at 62A. If you need more power, captain, a 10SI 94A from mid 80's Camaro or Monte is on the shelf at your local auto parts and will drop in.
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 02-19-2014, 08:09 PM
Txbobcat Txbobcat is offline
Ok so what you have is a very dependable alternator with more output than the external alternator. Leave it where it is at.
Old 02-19-2014, 09:59 PM
stone7777's Avatar
Thanks for all the help.
I ordered one from Ames this afternoon.
Only down side, 8 week wait!
