Old 02-19-2014, 08:39 PM
Brewster7376 Brewster7376 is offline
Default Question on piston damage
Been holding onto these pistons for a while I was thinking about using them for a build. like a dummy I just had them in a box no padding. did I screw up storing them improperly or are these dings trivial v
Old 02-19-2014, 09:32 PM
arcitech's Avatar
arcitech arcitech is offline
Budget build with a little cleanup, might be O.K. Are these stock? .030? What engine?
I'm partial to not using anything that might be a problem later. I guess it depends on your cash flow and luck.
Old 02-19-2014, 09:38 PM
Building a motor for a class I'm in if it turned out ok was thinking about putting in my formie
Old 02-19-2014, 09:39 PM
455 cast pistons 030 over
Old 02-19-2014, 11:21 PM
arcitech's Avatar
If you have a good instructor, then he should be able to tell you what you can and can't do with that damage. It seems pretty superficial, but it all depends on how well you prep your build. Cast pistons are pretty forgiving, so I don't see much of a problem trying to use them. I would be careful and make sure that the block they get used in will/can be bored to match the pistons after they are cleaned up and the nicks taken care of.
If it is for your learning experience, I say go ahead and try it out, just don't spend a lot of money on it. I would hate to see a serviceable block be trashed by marginal pistons. That being said, the pistons could be turned down to .020 over, if the block is still standard then you would only need a matching bore. Everyone could be happier and you would have a nice power unit.
Old 02-20-2014, 12:34 AM
Will Will is offline
Originally Posted by arcitech View Post
the pistons could be turned down to .020 over, ...
How, exactly, would you do that???
Old 02-20-2014, 09:38 AM
PONTIAC DUDE's Avatar
Thumbs up
Get a fine cut file and make sure the rings move freely in the grooves all the way around. File the high spots on the nicks flush with the area around it. As long as the vertical in groove ring clearance isn't worn from previous use. Use em and go have fun.
One can get anal retentive on this but if you have seen the shape of some pistons pulled out of perfectly good engines and running great.............................
Old 02-20-2014, 09:50 AM
The rings feel nice and tight I used some fine paper folded to take away any high spot in the groove rings don't catch on any spot. But are still tight
Old 02-20-2014, 05:07 PM
arcitech's Avatar
With one of these: http://etrema-usa.com/products/ams/
Old 02-20-2014, 05:28 PM
mrrat1 mrrat1 is offline
rings should be able to move freely around in the groove.
I had a set of pistons put on rods and the "machinist" clamped down on the ring area and I had to file out a couple spots on a few pistons to get the rings installed properly.
Old 02-21-2014, 12:17 AM
lust4speed's Avatar
Ken's recommendation of a file is what is needed. Sandpaper takes a little off both the high spots and the low spots, and doesn't really accomplish anything. A decent file will float around the ring land until it comes across a high spot, and you will know it when it finds one - easy to remove the tight areas.
Mick Batson
Old 02-21-2014, 02:14 AM
Yep, that'd do it. Wonder how many people have access to one of those?
Old 02-21-2014, 08:38 AM
steve25 steve25 is offline
Even if the rest of the piston is perfect the compression ring groves need to be checked by incerting a new ring and checking the verticle clearance.
If you find more than .004" due to ware, then dont expect to get good ring seal/ low blow by numbers!!
Old 02-21-2014, 08:39 AM
I think I'm just going to get a new set of pistons don't want to chance anything
