Old 02-21-2014, 03:48 PM
Nitebird Nitebird is offline
Default Does Harland Sharp rocker arm kit come with everything needed?
I have a new set of Edelbrock D port 87cc completely assembled heads. They will be going on a Pontiac 455 with Old Faithful cam. I would like to use Harland Sharp 1.5 rockers on it. Do I need to purchase a Shim kit along with the Rocker Arm kit?
Does their rocker arm kit come complete?
Old 02-21-2014, 05:05 PM
jww jww is offline
The H/S roller rockers I bought @ Summit or Jegs (forget which) came with polylocks and nothing more.
Jerry
Old 02-21-2014, 06:46 PM
WARPed's Avatar
WARPed WARPed is offline
HS rockers are complete as far as a set of stud rockers go. Not sure what makes you think you need beyond the parts suppled. Not sure where you think you will need shims - for a Pontiac anyway. If you were using shaft rockers then yes you might but not a stud style rocker system.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
