Old 06-05-2000, 12:46 PM
Bob W Bob W is offline
Anyone know the best way to wire HEI distriptor in a 69 GTO wiring Harness.I'm putting a 72 455 with HEI in my GTO that has a RAM air wiring harness.What's the best way so I don't have to cut alot of wires?
Old 06-05-2000, 11:03 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
The easiest way is to trace the stock resister wire back to the main connector. This is the one on the firewall. Pull the connector carefully remove the resister wire from the main plug. Using a larger gauge wire (12) Put it in the plug using another connector. You might have to look to find the right one. You might be able to reuse the origional one. Remember, it is going back in the same spot as the resister wire in the plug.
Try calling CRUSHPROOF! 512-386-9889
