Old 03-30-2014, 01:36 PM
87yjtoy 87yjtoy is offline
Default Got a 70 Formula
Was scanning craigslist yesterday just after lunch. Saw an add for a 70 Formula, clicked on it and in the description it listed a 3 speed trans. looking further at the pictures it looked rough and had the wrong hood on it but called the guy anyway. Yep ,3 speed, second owner, had it 35 years. used to have 455 in it but now has this 400.
So I tell him I would like to come look at it. Get there and it is pretty rough. Needs entire rear clip. Had a vinyl top on it at one time, and it was not kind to the car. Yes it is the original trans.
Ok its a cool car I could use the engine for my 55 GMC build. Make the deal and get the car. Check and find its a pretty rare option car. will post some pics when I get it home.
Old 03-30-2014, 01:50 PM
Held for Ransom's Avatar
Pat, if you ever remove the trans. I'm sure a few people will be interested in pictures and casting numbers of the components and shifter.
Old 03-30-2014, 03:48 PM
I recommend you run the PHS before doing anything with the car, out of the 689 Ram Air III formula's, 15 of them came with the M13 3 speed manual trans. You never know!!!
Old 03-30-2014, 05:33 PM
johnta1 johnta1 is online now
Agree with HFR and eaglesan13.
Would be nice to get more info on it.
(cowl tag info, paint color etc)
Congrats on getting it.
If it is a 3 speed Formula, there are 2 on PY that have one I believe.
Old 03-30-2014, 06:40 PM
Just got the car home and looked at it good. And all I can say is its rough, Vin 226870n1 looks like 70 formula. Correct? Cowl tag is ST 70 22387 nor 726427 bdy
TR 208 51 51 pnt
C4B W66
Car is Dark Blue with black High back seats has fiberglass hood that the PO cut off the snorkels to put a scoop in the center for carb clearance. underside has round holes with wire mesh covering them. looks like the correct stuff. Really sad about the condition of this car. Started it up and loaded on the trailer. drove it down the road, drove great strong motor, shifts nice. But did I mention how rough it is? oh well now for the decisions. Advice anyone.
I like this small window car better than my 76 formula.
Old 03-30-2014, 07:51 PM
2manyT/A'S's Avatar
W66 is definately Formula 400,,,,Goldenrod yellow with black std. interior....Is it original #'s matching engine?
Should have a 12 bolt rear axle.
Eye Candy......garage band?
Go full screen & turn it UP!
Old 03-30-2014, 08:11 PM
PO said this is not the original engine. Engine is YX with #12 heads. block casting is 481988 but I didn't look at the date code. It also has a Holley Street Dominator intake and holley carb on it. The yellow is visible all around the car. It does have the 12 bolt.
Old 03-30-2014, 08:18 PM
Car has 160mph speedo and tack with clock Std? and gauges in the center of dash. No a/c
Old 03-30-2014, 08:34 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
are the #12 heads dated prior to April of '70?
The gauges/tach were an option for Formula and could have been ordered on standard 400 or RAIII.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 03-30-2014, 09:33 PM
FunctionalShaker FunctionalShaker is offline
Getting interesting. Start posting pics, if you can.
Old 03-30-2014, 10:28 PM
165th's Avatar
165th 165th is offline
Agree, can't wait to see picture and PHS on this one.
Good luck with the refresh.
Old 03-31-2014, 12:14 AM
unruhjonny's Avatar
WOW!
Owner of a '70 L78/M13 Formula checking in!
It took me the better part of twenty years (no jokes) to get the correct transmission and shifter formy car - to this date I have not seen the reverse rod (linkage), but the original three speed switch is still here...
I would very much appreciate you considering me if you did a part out;
and if you decide to ressurect it, I'll help if I can.
There was one L74/M13 Formula in HPP many years ago, and I saw one L78/M13 Formula go on ebay about a decade ago (parts car)...
This is what my car looked like the day after I bought it in 1995;
1970 Formula 400
Old 03-31-2014, 07:19 AM
unruhjonny's Avatar
Originally Posted by 87yjtoy View Post
Cowl tag is:
TR 208 51 51 pnt
04B W66
... drove it down the road, drove great strong motor, shifts nice. But did I mention how rough it is? oh well now for the decisions. Advice anyone.
My cowl tag is:
ST 70 22387 nor 738845 bdy
TR 208 65 65 pnt
06A W66
I was going to leave mine yellow because I liked it that much
1970 Formula 400
Old 03-31-2014, 08:02 AM
I will get some pics up today, this car is nowhere near that good.
Old 03-31-2014, 09:07 AM
unruhjonny's Avatar
well, if you do decide to part, I would like opportunity to but the transmission, shifter, shift linkage, reverse light switch, and maybe even the driveshaft (my current driveshaft has the one end for my 12 bolt, and an input shaft for my M22).
There a recieving company in Montana that I deal with for bigger crap.
Does your car have the black shift ball?
1970 Formula 400
Old 03-31-2014, 03:18 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
It be a shame to cut it up.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 03-31-2014, 08:21 PM
OK, will try to post pictures. [/IMG]
76 Formula 400/350
Old 03-31-2014, 08:24 PM
Ok that worked a couple more
[/IMG]
[/IMG]
76 Formula 400/350
Old 03-31-2014, 08:25 PM
unruhjonny's Avatar
base hood with cheesy scoop
1973 bumper/grilles
late second gen camaro seats
but it looks to have good tires!
1970 Formula 400
more
76 Formula 400/350
