Old 03-20-2012, 03:13 PM
dedsleds's Avatar
dedsleds dedsleds is offline
Default updated list
XH 400 W/670 HEADS, TURNED ENGINE BY HAND SO NOT LOCKED UP, W/HOLLEY CARB, NON A/C PULLEY SETUP, HEADERS, T-400 TRANS, ENGINE HARNESS....... 800.00 ALL/COMPLETE
RATHER SELL IT WHOLE....MAY TRY TO SET IT UP TO RUN.....PRICE GOES UP IF I DO THAT.................BUT IF I PART OUT:
670 HEADS 400.00
AFB STOCK 4BRL INTAKE W/MATCHING VALLEY PAN 80.00
VALVE COVERS 25.00/PR
HOLLEY MODEL???? 35.00
POINTS DISTRIBUTOR 25.00
NON AC, PS COMPLETE BRACKET/PULLEY SETUP W/ALT AND PUMP 100.00
TURBO 400 LONGTAIL TRANS W/YOKE 150.00 W/COMPLETE DRIVESHAFT 200.00
XH CODE SHORT BLOCK ROTATING ASSEMBLY W/PAN & STARTER 400.00 OBO
HEATER HOSE BRACKET/HOLDER 20.00
FLOOR SHIFTER CABLE/BRACKETS/SHIFT LEVER ON TRANS 55.00/ALL
FLEX FAN W/SPACER 25.00
THE HEADERS ARE JUNK AND ROTTED OUT
REAR SIDE PANELS 40.00/ALL
GOOD REAR SEAT BOTTOM ONLY 30.00
UNTINTED GLASS L/R AND REAR all etched w/vin # ... 40.00 FOR ALL
ORIGINAL 3-4? CORE HARRISON RADIATOR 55.00
3 DRUM BRAKE RALLY 2 WHEELS 75.00/ALL
TAILLIGHTS......one has a slight crack...........pending sale
TAILLIGHT REAR PANEL INSERT W/ENDS ...........pending sale
DOOR JAMB VENTS 10.00/PR
L/R 1/4 GLASS TRIM 10.00/PR
ALL WINDOW REG/TRAX MANUAL 20.00/ALL
UPPER FAN SHROUD METAL PC 10.00
BLACK COAT HOOKS 5.00/PR
htr box w/vent parts/ vent kick panels 25.00/all
UPPER/LOWER CLEAN CONTROL ARMS 40.00/set
OPEN TO OFFERS ON MOST OF THIS STUFF....PACKAGE DEALS TOO!
1959 catalina 4dr a/c car
1970 gp strip car ...
1972 gp j 455/4
1971 bonneville hearse 455/4
1972 grand safari wagon 6 pass 455/4
1995 Firebird Formula 5.7 convertible
2002 gp 40th anniv. SC V6
2003 gmc sierra 2500hd 8.1 liter
***LIKE MY FACEBOOK PAGE https://www.facebook.com/GratefulParts***
http://stores.shop.ebay.com/GRATEFUL...__W0QQ_armrsZ1
  #82
Old 03-24-2012, 08:11 PM
dedsleds's Avatar
STILL HAVE TAIL SECTION SETUP...I THINK THE GUY BACKED OUT DUE TO SHIPPING COSTS.
IT IS 120 TO SHIP THIS TO THE WEST SIDE OF COLORADO....IT IS BOXED AND READY TO GO..........LOOKING TO GET AROUND 100 FOR IT...
ID:	279362   Click image for larger version
ID:	279363   Click image for larger version
1972 gp j 455/4
  #83
Old 03-27-2012, 11:15 PM
dedsleds's Avatar
Exclamation
well i took apart the engine...
PULLEY PS SETUP SOLD
67 400 BLOCK W/ROTATING ASSEMBLY 500.00 W OR W/O ROTATING PARTS
AFB 4BRL IMNTAKE 65.00
VALLEY PAN 25.00
OIL FILTER HOUSING 12.00
WATER PUMP/TIMING CHAIN HOUSING W/NEWER CHAIN 55.00
670 HEADS W/BOLTS 455.00
METAL TRANS INSPECTION COVER 20.00
HARMONIC BALANCER W/BOLT 20.00
ENGINE MOUNT BOLTS TO FRAME 12.00/PR
OK ENGINE HARNESS 5.00
VALVE COVERS 22.00/PR
STARTER FRONT BRACKET 10.00
INTAKE BOLTS W/HOSE AND WIRE HOLDERS 25.00
HEATER HOSE HOLDER 15.00
CAM ECCENTRIC W/BOLT 15.00
FAN SPACER W/BOLTS 12.00
HOLLEY CARB CORE 20.00
USED HEADER COLLECTORS W/BOLTS 10.00/PR
T400 LONGTAIL TRANS W/CONVERTER 80.00
SHIFTER CABLE AND ASSEMBLY OFF TRANS 45.00
DRIVESHAFT W/400 YOKE 55.00
SPEEDO CABLE 5.00
CUSTOMIZED 4BRL AIRCLEANER 20.00
FLYWHEEL/FLEXPLATE RING/BOLTS 10.00
AFTERMARKET SPARK PLUG WIRE HOLDERS 10.00/PR
18.5 INCH FLEX FAN 20.00
400 DISTRIBUTOR 25.00
DIST HOLD DOWN 10.00
CARB VACUUM TEE 15.00
ID:	279729   Click image for larger version
ID:	279730   Click image for larger version
ID:	279731   Click image for larger version
ID:	279732   Click image for larger version
1972 gp j 455/4
  #84
Old 03-28-2012, 03:32 PM
dedsleds's Avatar
CAME ACROSS:
3 SETS OF TAILLIGHTS (1 HAS A SLIGHT CRACK) 35-45.00/PR
FRONT VALANCE PANEL W/LOUVERS ADDED ON BOTTOM 40.00
REAR LIGHT LENSES 20.00/PR W/GASKETS
A BUNCH OF SETS OF FENDER/SAILPANEL/DOOR PANELS LETTERS/EMBLEMS 10-50.00 SET
ID:	279792   Click image for larger version
ID:	279793   Click image for larger version
1972 gp j 455/4
  #85
Old 03-30-2012, 01:59 PM
dedsleds's Avatar
pending sale on v/pan and trns insptn cvr
1972 gp j 455/4
  #86
Old 03-31-2012, 07:49 PM
dedsleds's Avatar
SOLD THE DASH
STILL HAVE VALLEY PAN
1972 gp j 455/4
  #87
Old 04-01-2012, 05:47 PM
dedsleds's Avatar
sold the hood hinges
1972 gp j 455/4
  #88
Old 04-04-2012, 10:03 AM
dedsleds's Avatar
sold
cam eccentric
intake
distrib holddown
console shifter cable setup
carb vacuum t
flex fan
ok engine harness
oil filter housing
1972 gp j 455/4
  #89
Old 04-04-2012, 10:05 AM
dedsleds's Avatar
Default 50.00
pics of newer style timing chain housing
ID:	280565   Click image for larger version
ID:	280566   Click image for larger version
ID:	280567   Click image for larger version
ID:	280568   Click image for larger version
1972 gp j 455/4
  #90
Old 04-04-2012, 11:21 AM
dedsleds's Avatar
scrapped wheel well:
CHEAP STUFF...SCRAPPING SOON
L/R DOOR LATCHES AND WINDOW REGS 20.00/ALL
HEATER BLOWER BOX/CORE 10.00
CONTROL ARMS 25.00/ALL
MISC UPPER SIDE WINDOW TRIM 10.00/ALL
MODIFIED AIR CLEANER 5.00
1972 gp j 455/4
  #91
Old 04-05-2012, 11:59 AM
dedsleds's Avatar
sold valley pan and distributor
1972 gp j 455/4
  #92
Old 04-09-2012, 04:53 PM
dedsleds's Avatar
Default UPDATED LIST
SOLD VALANCE
SCRAPPED WINDOW REGS, HTR CORE W/BOX, THREW OUT DUCTS
ALL I HAVE IS WHAT'S LISTED....EVERYTHING ELSE HAS BEEN SOLD SCRAPPED, THROWN OUT....
FIREWALL BLOWER BOX W/KICK PANEL VENT COVERS 20.00/ALL
REAR SIDE PANELS 50.00/ALL
GOOD USED NEWER FRONT COIL SPRINGS 20.00/PR
UPPER FAN SHROUD 4 CORE W/LOWER RADIATOR SUPPORTS 20.00
HEATER LOOM FROM SWITCH TO BLOWER RESISTOR, LOWER BUCKET SEAT CAR DUCT 20.00/ALL
UNTINTED GLASS L/R AND REAR ALL HAVE VIN # ETCHED ON GLASS 80.00 OBO FOR ALL
ORIGINAL 3-4? CORE HARRISON RADIATOR 75.00 (CORE IS WORTH 25-35.00 IN SCRAP. I WOULD CUT TANKS OFF AND SHIP ONLY TANKS)
TAILLIGHTS, 4 sets, 2 have slight CRACK.....15-30.00/ea
TAILLIGHT REAR PANEL 75.00
TAILLIGHT LOOM COVER (GOES UNDER REAR SEAT) 10.00
L/R DOOR LATCH ASSEMBLIES 40.00/PR
PILE OF SIDE WINDOW TRIM (DRIPRAIL/LWR DOOR 1/4 GLASS) 20.00/ALL
COAT HOOKS (BLACK) 5.00/PR
UPPER/LOWER CONTROL ARMS 75.00/ALL
a few fender letter sets 45.00/side
3 grill embs 5.00/ea
2 door panel emb. 10.00/pr
turn signal lense 30.00
reverse light lenses 23.00/pr
ENGINE PARTS FROM THIS CAR:
67 XH 400 BLOCK W/ROTATING ASSEMBLY 500.00 W OR W/O ROTATING PARTS
newer style WATER PUMP/TIMING CHAIN HOUSING W/NEWER CHAIN 55.00
HARMONIC BALANCER W/BOLT ....might be sold
T400 LONGTAIL TRANS 80.00
ID:	281161   Click image for larger version
ID:	281162   Click image for larger version
ID:	281163   Click image for larger version
ID:	281164   Click image for larger version
1972 gp j 455/4
  #93
Old 04-09-2012, 08:27 PM
dedsleds's Avatar
STILL HAVE:
400 DISTRIBUTOR 20.00
VALLEY PANE W/PCV IN REAR 40.00
1972 gp j 455/4
  #94
Old 04-11-2012, 10:06 AM
dedsleds's Avatar
THANKS TO HARRY "COACH", I HAVE A LOT MORE 67 GP MISC PARTS FOR INTERIOR, TRIM, GRILLS TO SELL....
FRONT BUMPER CORE (BARE) 40.00
COMPLETE GRILL ASSEMBLY, I MIGHT HAVE AN EMBLEM, MISC INNER BRAKETS 75.00
CLOCK BLOCK OFF COVER 20.00
NICE CLOCK 20.00
NICE GLOVE BOX DOOR W/LOCK AND GOOD EMBLEM (NO SHOWN) 15.00
MISC CONSOLE PARTS 15.00
MISC A/C VENTS (SHINEY) 10.00/ALL
NEAR NEW REARVIEW MIRROR BRACKET 15.00
NICE RADIO KNOBS 15.00
LIGHTER ASSEMBLY 15.00
LIGHTER 10.00
REAR SPEAKER AND ANT SWITCHES 25.00/BOTH
WIPER SWITCHES UNTESTED 10.00/ALL
IGNITIONS ASSEMBLIES W/KEYS 20.00 EACH (2)
NICE REAR ASHTRAYS 10.00/PR
L/R BLACK POWER WINDOW PODS W/SWITCH PLATES 1 SWITCH 50.00
L/R WHITE POWER WINDOW PODS ONLY W/PASS LOWER ARMREST 35.00
DRIVER'S SIDE GP TURN SIGNAL HOUSING W/PASS SIDE LENS ASSEMBLY 35.00
REVERSE LIGHTS W/SHIELDS 20.00/SET
L/R SIDE MARKER SETUP 50.00
L/R SIDE MARKER ASSEMBLIES 30.00
L/R SIDE MARKERS LENSES 15.00/PR
REBUILDABLE STEERING WHEEL 15.00
NICE FRONT BUMPER EMBLEM W/GASKET 50.00
NOS HOOD LATCH W/ROD AND SPRING 25.00
CONVERTIBLE REAR ARMREST LENSE ASSEMBLIES W/GOOD LENSES 50.00/PR
CONVERTIBLE REAR ARMREST LENSE ASSEMBLIES W/GOOD LENSES & SWITCH 60.00/SET
CONVERTIBLE INNER WINDSHIELD TRIM, VISOR HOLDERS CHROME PILLARS 75.00/ALL
NICE L/R 1/4 GLASS CHROME AND 1 NEW SEAL 25.00/ALL
TRUNKLID LIGHT ASSEMBLY 5.00
TAILPANEL L/R END INSERTS 5.00/PR
TRUNKLID LATCHES W/LOCKS AND LOCK HOLDERS (NO KEYS) 15.00/ALL
OK LOWER STAINLESS ROCKER TRIM PC 10.00
1 WHEEL WELL OPENING TRIM.......
1972 gp j 455/4
  #95
Old 04-14-2012, 12:14 PM
dedsleds's Avatar
SOLD THE VALANCE
PENDING SALES:
DASH SWITCHES
1/4 ROCKER TRIM
CONSOLE PARTS
ROCKER CLIPS
GRILLS
CONVERT INSIDE WINDSHIELD TRIM
ASH TRAYS
MY LAST GP GRILL EMB
PONTIAC BUMPER EMBLEM
1972 gp j 455/4
  #96
Old 04-16-2012, 08:18 AM
dedsleds's Avatar
pending sale on turn signal housing
1972 gp j 455/4
  #97
Old 04-17-2012, 12:43 AM
dedsleds's Avatar
sold:
DASH SWITCHES
1/4 ROCKER TRIM
CONSOLE PARTS
ROCKER CLIPS
GRILLS
ASH TRAYS
reverse lights w/shields
driver's side turn sig housing
1972 gp j 455/4
  #98
Old 04-18-2012, 08:58 PM
dedsleds's Avatar
SOLD DRIVER'S SIDE TURN SIGNAL HOUSING
1972 gp j 455/4
  #99
Old 04-24-2012, 09:02 AM
dedsleds's Avatar
Thumbs up UPDATED LIST....OPEN TO OFFERS
UNTINTED GLASS L/R AND REAR ALL HAVE VIN # ETCHED ON GLASS 30.00 FOR ALL
TAILLIGHT REAR PANEL 55.00
L/R DOOR LATCH ASSEMBLIES 30.00/PR
UPPER/LOWER CONTROL ARMS 40.00/ALL
3 door panel emb. 10.00/pr
turn signal lense 20.00
67 XH 400 BLOCK W/ROTATING ASSEMBLY 450.00 W OR W/O ROTATING PARTS
newer style WATER PUMP/TIMING CHAIN HOUSING W/NEWER CHAIN 50.00
670 HEADS W/BOLTS 400.00
VALVE COVERS 20.00/PR
INTAKE BOLTS W/HOSE AND WIRE HOLDERS 20.00
NICE CLOCK 20.00
LIGHTER 10.00
REBUILDABLE STEERING WHEEL 10.00
NOS HOOD LATCH W/ROD AND SPRING 20.00
TRUNKLID LATCHES W/LOCKS AND LOCK HOLDERS (NO KEYS) 10.00/ALL
1 WHEEL WELL OPENING TRIM.......20.00
8 LUG SPARE HOLD DOWN PLATE W/HOOK 35.00
PARTIAL JACK ASSEMBLY 25.00
NEW OVERFLOW JUG HOLDER 5.00
NEW EMERGENCY BRAKE CABLE 10.00
MISC POWER WINDOW SWITCHES 10.00/EA (ASK FOR PICS)
NEW DOOR LOCVK PILLAR SEALS 10.00 SHIPPED/PR
NEW CROSSMEMBER RUBBER INSULATORS 20.00/PR SHIPPED
NEW PILE OF BRAKE AND FUEL LIONE CLIPS 15.00 SHIPPED/ALL
PRETTY NEW TURBO MUFFLERS W/RESONATORS, HARDLY USED (ON CAR FOR AN HOUR), 40.00/ALL
MISC A/C COMPRESSOR BOLTS AND 1 SMALL BRACKET (REAR) 12.00 SHIPPED
FUEL LINE HOLDER 5.00
BATTERY HOLD DOWN 5.00
BATTERY CABLE TUBE 5.00
ID:	282628   Click image for larger version
ID:	282629   Click image for larger version
ID:	282630   Click image for larger version
ID:	282631   Click image for larger version
1972 gp j 455/4
  #100
Old 04-29-2012, 12:07 PM
dedsleds's Avatar
open to offers/package deals on this stuff......
1972 gp j 455/4
