Old 03-26-2024, 12:48 PM
llwta76 llwta76 is offline
Default rear sway bar bushing question
My 76 T/A has the original 13/16" rear sway bar. However the actual diameter is .806-.809" depending where it's measured. The area where the bushing rides is slightly warn smooth and measures .790" What poly bushings do I get? 3/4" and open them up or are the 13/16" bushings okay.
Thx, Larry
Old 03-26-2024, 01:21 PM
JLMounce JLMounce is offline
I would use the 13/16" bushings. You may consider adding a bit more grease to help take up the small amount of tolerance that has built up over the years.
-Jason
1969 Pontiac Firebird
Old 03-26-2024, 01:37 PM
Which bushings? there are 3 sets.
Old 03-26-2024, 02:29 PM
spring perch mount is .790. Hanger mount at clamp is actually .783-.790 ( somewhat egg shaped). The third is pretty good
Old 03-26-2024, 02:37 PM
If rubber I would go 3/4" and use lots of silicone lube.
