Old 08-12-2020, 07:34 PM
cnc's Avatar
cnc cnc is offline
Default Shaker hood repair
What is the best way to repair this crack which actually goes downward into the hood cut out as well ..I don’t want this to happen again...
Car is being stripped down for some paint and some bodywork this is one area I want to address...Thanks...Chris
ID:	547067   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 08-12-2020, 08:22 PM
400 4spd.'s Avatar
Weld it from the back side. The added thickness will add strength and let's you finish the exterior side without making it too thin to last.
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 08-12-2020, 10:06 PM
Authentic-242 Authentic-242 is offline
Whatever you do as a next step in the repair process, the first step is to drill a small round hole dead center at the end-point of the crack; this will prevent it from propagating any further into the hood after the chosen repair.
The Following User Says Thank You to Authentic-242 For This Useful Post:
Old 08-12-2020, 10:32 PM
400 4spd.'s Avatar
I disagree. A proper mig weld will prevent it from advancing.
Old 08-14-2020, 06:50 AM
cnc's Avatar
cnc cnc is offline
Ok thanks appreciate the feedback....
