#41
Yep, Jeff just called me today and said they were in and ready to sell. I have one on the way.
#42
Kauffman's
#43
Took them long enough.
#44
its a neat part they can make a little extra on when they sell a set of heads but is it even neccessary? my hi port combo ran fine pluged, my cv 1 combo ran fine plugged, my ehead combos are plugged. Granted nothing over 13.5:1 and most were 11.5:1.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#45
Not necessary at all but it will make KRE money because people think they need it.
#46
Website says 85. Mines plugged also ,maybe a street combo could use it better.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
#47
Mine is plugged with no issues.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
#48
Maybe to "hide" the HiPorts?
#49
That's the only reason i can think of to buy one, for looks.
Admittedly the crossover is cheaper than i expected it to be. |
#50
Its needed, I know of a street driven, high horsepower aftermarket block engine with High Ports. When it came apart after several thousand miles and trips to the track the engine builder, a Super Stock guy with excellent credentials said the front 2 cylinders showed signs of excessive heat.
No reason not to buy one as far as I am concerned. |
#51
#52
If that's the case you probably have to do some machine work to get it to fit.
It's sad you have folks buy it because they make it. |
#53
#55
The only reason there would ever be heat issues is if you blocked the bypass and didn't create another way for the water to bypass while the t-stat is closed. Once the t-stat opens it's normal flow at that point |
#56
That's relative...in the hot part of the summer doing highway driving ( 60 + miles) or long stop and go traffic I have seen it at 200.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
#57
The crossover showed up. It looks really nice. Quality is better than the Warrior crossover next to it.
The water openings on the sides are noticeably smaller than the Warrior. I may enlarge them. I run a 160deg thermostat. And always have a 1/8" hole in there just so I don't get a air pocket while filling. Not for any by pass reason. You can see the obvious casting flaws in the Warrior unit. Small batch casting. Ugly but it still worked. |
#58
Looks nice. Just hope they don’t leak coolent like there blocks.
The Following User Says Thank You to t money For This Useful Post: | ||
#59
The casting is far better than the Warrior casting and they are not known for leaking.
#60
Yeah the casting quality of the S-K and Warrior intakes was kind of crude...
Thread Tools | |
Display Modes | |
