Old 07-19-2020, 11:58 AM
napster's Avatar
napster napster is offline
Default Intake question on RA II Heads
I posted this in the street section and thought I would also post it here.
This is most likely a stupid question, but can a reproduction RA IV intake manifold be used on RA II heads or am I painting myself into a corner and have to use 234 intake. It seems from my research that the RA II head is a hybrid. Meaning d port on the intake side, hence my question.
Old 07-19-2020, 03:08 PM
johnta1 johnta1 is online now
The intake will fit no problem.
The intake ports will probably be a little taller than the port on the head.
I would use it, may not be optimum, but better than the cast iron intake.
(IMO)
Old 07-20-2020, 11:42 AM
brians's Avatar
brians brians is offline
Had a number of the aftermarket intakes. All were closer to the std. port size. If you get one, make sure you also clean it out good.
“If you ain't first, you're last” - REESE BOBBY
Old 07-20-2020, 05:10 PM
napster's Avatar
(IMO)
John.
I decided to go with the 234 intake. Reason is money. The work necessary to correct the repro RA IV intake that I have would have been very costly. Way more than the cost of a 234 intake.
Some of the repro RA IV intakes are way off. I have one of them.
Jim
Old 07-25-2020, 08:42 PM
Half-Inch Stud's Avatar
Well i prepped a4234 intake for the RAM IIs but ended up with a Spreadbore P4B for now.
Maybe after some 1/4 mile runs i will put the 4234 on and enjoy awhile.
