Old 07-23-2020, 12:18 PM
supersport#69 supersport#69 is offline
Default Finally some progress
I took some pics of motor trans numbers after pulling them out of the car. I pulled them to change oil pan gasket and rear main seal. It’s painted (except I have to repaint the oil pan now) and just waiting on gaskets to reinstall.
ID:	545619   Click image for larger version
ID:	545620   Click image for larger version
ID:	545621   Click image for larger version
ID:	545622   Click image for larger version
Old 07-23-2020, 12:30 PM
Default More pics
I was able to confirm my trans and motor both matched the vin so I was happy about that. There’s 68k miles on it. The only thing that I could see was the timing chain had been replaced. I’ll reinstall it next week and upload some pics.
ID:	545624   Click image for larger version
ID:	545625   Click image for larger version
ID:	545626   Click image for larger version
ID:	545627   Click image for larger version
Old 07-23-2020, 01:13 PM
Default More pics
I painted the manifolds but I’m repainting them a darker shade.
Old 07-23-2020, 01:17 PM
dataway's Avatar
dataway dataway is offline
Looks great!
Old 07-23-2020, 02:07 PM
Verdoro 68's Avatar
Looking good! Another Arlington car built around the same time as mine. They must have been cranking them out!
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-23-2020, 04:16 PM
dataway's Avatar
That's a manual trans right?
Old 07-23-2020, 09:13 PM
Yes it’s a 4 speed Muncie but not sure if wide or close.
Old 07-23-2020, 09:19 PM
A few trans pics
ID:	545654   Click image for larger version
ID:	545655   Click image for larger version
Old 07-29-2020, 08:45 PM
Today the pan gasket and 2 piece rear main seal was installed. Added New motor mounts and painted exhaust manifolds,
ID:	546043   Click image for larger version
ID:	546044   Click image for larger version
Old 07-31-2020, 03:43 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Looks terrific, nice work! From the oil pan drain plug, it appears that you have a later model oil pan instead of a 1968-69 pan. Those pans had the drain plug in the center rear of the sump, facing toward the rear of the car.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 07-31-2020, 04:04 PM
dataway's Avatar
Feels good don't it
Old 07-31-2020, 05:41 PM
Oh ok. That’s a bit odd original owner would change out the pan. Maybe damaged. Hopefully my gaskets hold up and don’t leak.
Old 07-31-2020, 05:59 PM
Drivers rocker had some damage from an old accident so pan was probably damaged too.
I’m thankful it’s never been rebuilt and still has original carb and exhaust manifolds. The distributor had a later date so that was probably swapped at some point. There’s about 69k on the engine. The Muncie hasnt been open either and shifts fine, although I did resurface flywheel and replace the clutch since it’s out.
Knock on wood it’s got a lot of cruising left in it before having to rebuild.
