Old 06-23-2013, 01:58 AM
edvisme edvisme is offline
Thanks johnta1, useful info there
Here are some more pictures of the car. Its strange at how rusty the trunk pan and quarters are then to find the floor pan in perfect condition. There isn't any rust to be found on the inside floor. I have yet to get the car on stands and roll around under it to see what the under side floor looks like.
I have a complete set of the 14" wheels. I like those wheels but, I'd much rather have a set of them in a 15". Anyone want to trade?
I will have a lot of parts and pieces off of this so if any of you need something that this may have, I can get you hooked up. That is if the part is there and in good condition.
ID:	327350   Click image for larger version
ID:	327351   Click image for larger version
ID:	327352   Click image for larger version
ID:	327353   Click image for larger version
  #82
Old 06-23-2013, 07:19 AM
njsteve's Avatar
njsteve njsteve is offline
I could use all six sections of the body side moldings if they are the factory installed ones that are bolted (not taped) onto the car. These are the stainless moldings with the black rubber center sections, for protectng aginst door dings. Could you post a close up of the trim sections on the front of the quarter? I should be able to tell if its a factory piece from that. Thanks, Steve
  #83
Old 06-23-2013, 10:18 AM
Here ya go, NjSteve. They do look like they could be original. Some of the ends are missing but the mouldings look to be in useable condition.
ID:	327375   Click image for larger version
ID:	327376   Click image for larger version
ID:	327377   Click image for larger version
ID:	327379   Click image for larger version
  #84
Old 06-23-2013, 11:16 AM
njsteve's Avatar
Those are aftermarket ones. The originals are stainless and do not have detacheable ends. Thanks for posting the photos. Here is an original:
ID:	327381   Click image for larger version
  #85
Old 06-23-2013, 11:22 AM
No problem with the pics, glad to do it.
  #86
Old 07-22-2013, 09:58 AM
I have the donor sub frame off the car, disassembled and ready to go off to media blasting. Tell ya, I had a heck of a time getting those rear bolts of the lower control arms off. The bolt had rusted to the inside of the bushing.
I am looking for a company that makes ALL of the brake and fuel lines. I want to go stainless, too. Can I get some feedback on who does good aftermarket remakes on these?
  #87
Old 07-22-2013, 10:23 AM
Cerberus's Avatar
Cerberus Cerberus is offline
Check with Inline tube. I believe they will have everything you need.
  #88
Old 08-18-2013, 12:54 PM
Update on the build. I took the sub frame, control arms, spindles, sway bar, radiator support, bumper brackets and some other parts off of the 70 Esprit parts car and 5 15x7rally II wheels to be media blasted. Started on the wheels last Tuesday and finally blew the clear coat on them yesterday.
These wheels are very time consuming. The sanding and making took hours and hours. The colors may or may not look correct for these wheels but I am not at all concerned with the accuracy of the colors. I think they look great all glossy, too. Next week I will get them mounted up to the tires and bolt them on the car.
Next part is the sub frame. I am going to re-weld the factory welds then get color on it this week. Its going to be a lot of fun swapping out the sub frame. The good part is I have all of the new parts collected for the job.
ID:	333768   Click image for larger version
ID:	333769   Click image for larger version
ID:	333771   Click image for larger version
ID:	333772   Click image for larger version
  #89
Old 08-19-2013, 09:30 AM
Formulajones's Avatar
Originally Posted by 2manyT/A'S View Post
Guys that have a T/A AND a Formula,DON'T have spoilers on their cars...
Wrong
Edvisme, Good find. Seems harder to find these cars that aren't canabolized, good start though. Looks like you are wasting no time setting things straight.
Another Coronado Gold RAIII owner here, good color combo Keep the pics coming.
  #90
Old 08-19-2013, 04:27 PM
Thanks Formulajones. Finally! Got the wheels done and installed today. Still need to snap the new trim rings on em. I'm going to delay that for as long as possible because once they go on, they will always be on due to scratching the pretty paint.
ID:	333890   Click image for larger version
  #91
Old 08-19-2013, 06:49 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
The wheels look GREAT, and here's the first vote for NO TRIM RINGS. You'll find that there are several PY'ers that feel the same way.
Here are a couple of shots from my old cars as examples . . .
ID:	333894   Click image for larger version
Regards,
"455HO" Lloyd
  #92
Old 08-19-2013, 07:29 PM
I do like the look with out the rings A LOT. How ever, I do like the rings on them, too. I bought a complete set of new rings so I'm tempted to snap one on just to see how it looks.
  #93
Old 10-23-2013, 11:50 AM
Well, its on now. I sold the hood off the car this last Monday so its time to tare the car down and rebuild it. Soon after it was gone I tore into the front end. She's been abused badly over the years. I found some damage under the right fender. The outer firewall has been pushed in due to a crash, then a scab repair was attempted to pull it out. I get to replace that section along with the rocker panel on the right side.
Funny how even the biggest projects can become even bigger.
ID:	340586   Click image for larger version
ID:	340587   Click image for larger version
ID:	340588   Click image for larger version
  #94
Old 10-23-2013, 12:33 PM
2manyT/A'S's Avatar
Open the can and the worms WILL crawl out.......hopefully that's the worst of it...
Eye Candy......garage band?
Go full screen & turn it UP!
  #95
Old 10-23-2013, 01:07 PM
Sheesh, parts are expensive! I just blew through a grand on Classic Industry's site. I bet I spend another 5 grand on this before shes rolling down the road this spring.
That's for sure, 2manyt/a. Tell ya, I am sooo glad I happened upon that 70 esprit parts car, and it being an a/c car to boot. The a/c box on mine has been "repaired." I didn't notice it until the fender was removed. whomever did the "repair" on the formula when it was t-boned, fiber glassed the a/c box (scab repair.) Good thing I have a good one off the esprit. Plus, I'm going to cut the firewall end cap off the esprit car and weld it in place on the Formula. I will be a busy man through the winter.
  #96
Old 10-23-2013, 02:29 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Wink
X2 on leaving the trim rings off. Much tougher looking without them. Get a spare set of wheels if you want to run the rings occasionally.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #97
Old 10-23-2013, 03:03 PM
Norwood's Avatar
Norwood Norwood is offline
Hey Bob...My Buddies Magnum just turned 200,000 and never been in the shop once. Love those Dodges
  #98
Old 10-26-2013, 12:24 PM
The past couple of day were spent taking the interior apart. I tool everything out, even removed the dash. Once I removed the gages I found that they were not "original" to the car. I'm learning about these cars so folks, go easy on me The tach and all the gages were "spliced" into the original wiring harness. Plus, many other cuts and hacks were done to the harness through out the car. I went ahead and bought a complete wiring harness from American Auto wiring. The tech there told me that this wiring harness will be just like if I went into a Pontiac Dealership in 1972 or so and needed it. AAW bought all the wiring jigs and diagrams for these cars. I will report on its quality once I receive it.
Now onto the fun part. When I checked out the car before I bought it the floors and all the underside looked solid, rust free. Right! The interior side has some issues. Both drivers and passengers side foot panel look like swish cheese. Plus the passenger side panel under the passenger seat, too. So I'm at a wits end now. Not sure what path to take. Either patch it together or go the gusto and do a complete floor pan. Also, I found that the car had been converted to a manual trans in its life. There's a hacked up patch panel over the hole where the floor was cut open for the shifter.
Oh well, these cars are a labor of love. Looks at though I get to add another 100 hours to the build time
  #99
Old 10-26-2013, 01:17 PM
Tazzz2's Avatar
Tazzz2 Tazzz2 is offline
For what it's worth American Auto Wire has a awesome reputation of reproducing a headache free Top quality harness... While I don't personally do the electrical installs on my builds at 54,,, I have used them for years on "all of my birds and have never had an issue" (or a phone call complaining about this or that) or been disappointed with the products they have delivered... They have done everything from stock harness to all out custom built harness work for the custom gauge and LS conversion we've done as well... 100% top drawer company in my books...
albertmelchior@gmail.com
The Following User Says Thank You to Tazzz2 For This Useful Post:
  #100
Old 11-05-2013, 09:50 PM
2manyT/A'S's Avatar
Default Food for thought....?
Spotted this in the Firebirds for sale...
Seems to have ALOT of what you need to repair/replace on your car....
Not real pretty,but hopefully NO nasty surprises....
http://forums.maxperformanceinc.com/...d.php?t=740774
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
