Old 02-04-2024, 03:29 PM
ericisback's Avatar
ericisback ericisback is offline
Default Need feedback on a 65 my friend is considering
My friend is considering purchasing this 65 389 coupe, that is being auctioned in an estate. The online auction ends in two days. I was wondering if I could get some feedback from the group regarding the car, and any issues, or problems that you see based on the listing.
https://bids.hbarrysmith.com/auction...d-descriptions
I inspected the car today. Here are some of the things I noticed:
The car won’t start without a jump. At first, I thought it was the battery, but the car will only idle for about a minute or two before it quits, and then needs to be jumped again. It does not seem like the battery to me. What are your thoughts?
Stampings and date codes seem correct on the engine. However, when it was sold in 2017 at Mecum, the listing mentioned a protect-o-plate. The protect-o-plate is no longer with the car, so I’m wondering what happened to it, and additionally, now I cannot verify that the engine is original.
Although the listing does not show the PHS documentation. I was able to take some photos of of it at the viewing.
Two of the three carburetors have the correct tabs - couldn’t see the carb codes.
Car has the correct heads based on the stampings and the date codes.
Intake manifold seems correct.
Car has aftermarket (Dougs) headers
The car sold at a Mecum auction in 2017 for $66,000. It still has the Mecum sold sticker on the windshield, and the license plates in the rear floorboard.
I will try to attach some photos that I took today. Please let me know what you think.
ID:	627933   Click image for larger version
ID:	627934   Click image for larger version
ID:	627935   Click image for larger version
ID:	627936   Click image for larger version
1965 Buick Riviera GS
1965 GTO Tri-Power convertible
1965 Jaguar XKE Series 1 Coupe
1967 Corvette L68 convertible
1967 GTO 400 convertible
1968 Camaro 396 SS/RS convertible
1969 Plymouth GTX 440
1969 Mach 1 R-Code Cobra Jet
1970 Olds 442 W-30
1970 Buick GS 455 Stage 1
1970 Dodge Super Bee Hemi
1978 VW Beetle convertible
2011 Mercedes SLS
2013 Jeep Wrangler Rubicon
Old 02-04-2024, 03:34 PM
ericisback's Avatar
More photos:
ID:	627938   Click image for larger version
ID:	627939   Click image for larger version
ID:	627940   Click image for larger version
ID:	627941   Click image for larger version
1970 Olds 442 W-30
2011 Mercedes SLS
Old 02-04-2024, 08:51 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Looks like a clean ride. If you want to get picky, and this drives the '65 guys bonkers, the front seat lower cushions are reversed. Date codes appear to be within the build date. Trans case should be stamped with the VIN if you need to confirm originality. I think the matching #s and a great auctioneer got a premium price in'17.
65madgoat's Avatar
Old mecum auction page:
https://www.mecum.com/lots/295735/
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 02-04-2024, 08:54 PM
65madgoat's Avatar
Nice car. Get a proper steering wheel on it and you are in business. Could just be a bad alternator. Regardless with any used car you will need to go through it.
A matching numbers tripower 4 speed still worth at least in the $60s in this shape I feel. Great color. Cool goat.
1st gen GTO market has been soft for over a decade. So really don't see it getting above where it sold at mecum. Anything under a win.
Old 02-05-2024, 12:54 AM
You will have to base its condition top and bottom yourself.
I could only view 2 pics on Mecum site , of the dash/interior only.
Not sure if correcting the seat bottoms can be done with just nuts and bolts.
The lines should mimic the back seat directions.
Red car painted Black
Headlights and connectors are reversed or they only work on high beam.
Only the bottom bulb is burning.
Late 70's TA splitter repops are almost a common sight , but the installation is really poor.
Correct all green tach line for an early'ish car.
Carb tags are available in the catalogs.
Need to get the casting numbers off the center section of each carb.
7 digit numbers that are cast in raised numerals.
A better car would bring way more than this one.
They overpaid at Mecum from what I see.
Not running and driving puts it about 50-55k top dollar.
That's if everything else you can see top and bottom is proper.
50 and under seems kind of safe place to be on it.
I'd rather find a car in a factory color I liked , and was still that color.
The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
Old 02-05-2024, 01:02 AM
65madgoat's Avatar
100% what he said
Old 02-05-2024, 01:16 AM
I did see your pics and the ones on the current auction site.
Don't think there was anything showing underside condition..
Old 02-05-2024, 01:50 AM
Looked at auction site again and there are more pics than I saw the first time.
Was wondering how there were comments on the dates etc ... Haha
Distributor is a later model with aluminum housing. March 9 1972
Should be a cast iron housing with a stainless steel ID band around the lower neck.
Its probably a good car overall and they don't all have to be perfect.
Mainly you just dont want cheesy workarounds like that horn button or the tailpipes.
And the seat bottoms backwards
Rims are always subjective to personal tastes
Old 02-05-2024, 04:04 AM
ericisback's Avatar
Thanks for this great info!!!
1970 Olds 442 W-30
2011 Mercedes SLS
Old 02-06-2024, 04:53 PM
ericisback's Avatar
Im stunned! Based on my thoughts, and the feedback here, my friend decided to bid the car up to $50k, including all fees.....
The car sold for $77,500 PLUS 10% auction fees AND 7% state sales tax, for a total of $90,675.00. You could knock me over with a feather.
Prices have gone crazy!
1970 Olds 442 W-30
2011 Mercedes SLS
Old 02-06-2024, 04:55 PM
65madgoat's Avatar
That is A LOT for a car in that condition. Plenty other 1965 goats out there but (may not be numbers matching tripower and 4 speed). Granted finding that is not easy, but no way did I see $90k for this car. But it was worth it to one person!
Old 02-06-2024, 05:11 PM
ericisback's Avatar
Without the protect-o-plate it’s not even guaranteed original engine. I guess it is as “matching numbers” as a 1965 can be without build sheet or protect-o-plate.
Tri-power, 4-speed IS rare for sure, but not even original color. I’m scratching my head.
1970 Olds 442 W-30
2011 Mercedes SLS
The Following User Says Thank You to ericisback For This Useful Post:
Old 02-06-2024, 05:47 PM
Maybe the 65 3x2 4spd 3.90 project on eBay is worth buying and restoring after all.
They did build a lot of 65 3x2 cars , but 3.90 cars are hard to find
This hobby is still full of surprises - wow
90k with those drawbacks is above and beyond
Old 02-06-2024, 05:57 PM
johns johns is offline
IMHO-change to stock wheels, dog dishes and red line tires. $65000 max.
John S
ericisback's Avatar
Less than three out of every ten ‘65 models were factory tri-power… granted, there were more four speeds than automatics in 65, but the combination does not show up a lot nowadays…. At least not from the factory.
1970 Olds 442 W-30
2011 Mercedes SLS
Old 02-06-2024, 06:17 PM
Keith Seymore's Avatar
Or two people.
Usually it takes more than one person that wants it bad to drive the price up.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
The Following 3 Users Say Thank You to Keith Seymore For This Useful Post:
Old 02-06-2024, 11:56 PM
Over 20,000 tripower GTO's in 1965
The better cars with great color combos and correct drivetrains don't move around a whole lot..
Guys have seemed to hold them pretty tight for extended lengths.
