Old 02-18-2024, 09:09 PM
6t5gto 6t5gto is offline
Default Ignition coil
Is the correct ignition coil for a 12B build date a 202?
The Following User Says Thank You to 6t5gto For This Useful Post:
Old 02-18-2024, 11:30 PM
Is this correct for a 1965?
Old 02-19-2024, 12:17 AM
Bill Hanlon's Avatar
According to Pontiac Chassis Parts Catalog published in Oct 66 the GM part number 1115202 (note the last 3 digits) is used on a 62-63 Tempest 4 cylinder
engines, 64-66 Tempest 6 cylinder engines and 55-57 except dual quad and 3-2 two barrel carbs. Correct part number for a 65 GTO coil is 1115207 (transistor ignition) or 1115134 (points ignition) .
All Pontiac coils from 1948 thru 1966 are part number 1115xxx. I wouldn't bet my life that the last 3 digits being 202 was shorthand for 1115202, but I'd bet yours.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
