Smaller water pump pulley?
Looking to spin my water pump faster, know what year pulleys would work?
Currently have stock 74' pulleys, looks to be 7.25 crank and 8.0 water. Ooops, this should be in the heating/cooling tech section.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. Last edited by BILTIT; 06-28-2009 at 09:49 PM. |
Check with the Goat Farm.Shemp the Bat is a member here.Thats where I got mine $30-$35.
Got one off ebay which looks like it will work, 5 5/8'' diameter.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
http://cgi.ebay.com/ebaymotors/71-72...4506.m20.l1116
This is what i bought. Will update when i get it installed.
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
No you won't. They just e-mailed me that the pulley is just a 6.5 incher - not the 5 5/8" they advertised.
Same here; back to the drawing board!
The 1971 and up cars that had air had the 6.5" diameter water pump pulley and a 8" diameter crank pulley.
smaller driven pulley =slower speed, larger driven pulley=higher speed
Smaller crank pulley (or larger pump pulley) = slower pump speed Smaller pump pulley (or larger crank pulley) = faster pump speed |
62Lemans is correct.
Just find pulleys from any 71-79 Pontiac V8 with A/C. All use; 8" crk 6-5/8" wtr pump
You don't win the prize, not even a consulation prize or a nice parting gift! Thanks for playing...
Mine is in the mail. 6.5'' or whatever it is will be better than my ~8''.
I'm checking the math on that. So your saying that a larger pump pulley rotates faster than a smaller one if the crank pulley remains the same size?
What?...aaa?...
Now i'm confused.
No, the smaller the WP pulley the faster your pump will spin regardless of the present crank pulley size.
Pulleys are just like gear sets. Every crank gear has twice as many teeth as the cam gear (and is 2 times larger)! The factor is two. So the cam turns 2 times for 1 time of the crank - in a 4cycle engine anyway. |
You must be dyslexic. The cam gear is twice the size of the crank gear. The crank spins twice for every spin of the cam.
Why is he not suspended? |
Ok, try to visilize the pully speed on a non-A/C system(7" crk and 8" w/p).
Now A/C system(8" crk and 6-5/8" w/p). Which set would spin the w/p faster.
The crank gear is smaller and the cam gear is bigger. Its been a while since I changed a timing chain or belt (about 40 years). |
