Old 07-02-2018, 02:50 PM
NYGTO's Avatar
NYGTO NYGTO is offline
Default 1965 - 389 Water-Pump Part Number
Hey guys, can someone please let me know what part number and proper date code I would need for a 1965 GTO late Mate build car? thanks of if anyone has one they would like to sell please p.m. me. Thanks again
Old 07-02-2018, 07:32 PM
No production dates til mid '67 production. Can go out and ck my supply of cores, know I have a few nice early cores with the late '63-64-65 design cast impeller.
Old 07-02-2018, 07:54 PM
bill ryder's Avatar
bill ryder bill ryder is offline
I believe the casting # you are looking for is 9772716. No date code on housing. "Bill"!
NYGTO's Avatar
That would be great. Thanks for reaching out.
Old 07-03-2018, 08:20 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Here is the correct pump
ID:	486970   Click image for larger version
ID:	486971   Click image for larger version
Old 07-03-2018, 05:47 PM
Jack P. Jack P. is offline
Keep in mind a later and better impeller will fit on a early pump, looks correct and actually flows.
Old 07-03-2018, 08:38 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
If you know the history of the engine maintenance and the water pump has never been changed, then have it rebuilt.
There are specialists in every component on these cars such as the water pump,
I pulled my OEM water pump off my 65 because it was leaking. Turns out the shaft was loose because of a worn bearing.
The gentleman that replace the bearing also sets the gap between the impeller and the single divider plate per factory.
GM designed it to work as intended and now my unit operates perfectly.
PS, I requested to leave the Original Paint on my pump to match back up with the timing cover.
Chris.
ID:	487029   Click image for larger version
ID:	487030   Click image for larger version
ID:	487031   Click image for larger version
ID:	487032   Click image for larger version
Old 07-04-2018, 01:44 PM
GT182's Avatar
GT182 GT182 is offline
Make sure you get one that the impeller's curvature matches the curve of the inner divider plate. If it has a curvature. The matching up of them will keep the pump from having cavitation and not cooling as it should. Check the heating and Cooling Tech section.... the top Sticky thread - "Chalk up one more for the cast impeller." This is the one you want to read.... all of it. Or you can skip to about Page 51 or 52.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 07-05-2018, 12:20 PM
John V. John V. is offline
Be aware that the same pump body casting was used for the '63 4 cyl water pump.
Different pump assembly p/ns for the 4 cyl pump vs. V8 pump were assigned as seen in the MPC but the only way they are identified is by the p/n on the pump body casting.
Several years ago another member and I studied them and it seemed the 4 cyl version used an impeller with shorter fins. IIRC, there was an NOS pump being advertised at the time but was the 4 cyl version.
The one I had rebuilt had no codes that I could find. But I also have one that is stamped with nos. on the end of the pump shaft on the pulley end. It may or may not be a date code.
It shows a "W" and below that it shows "6406-1".
I was never able to find other examples with a similar shaft end stamping to derive any meaning from it. My sense was that the one that was stamped was an original shaft. But other than the fact it has no shaft stamping, I had no reason to suspect my other pump has anything but the original shaft installed in it.
I do agree with the other comments, no cast date code on the pump body as seen on later model pumps. Although I can't recall if I'd ever seen a Service Replacement '64-'65 Water Pump with the 9772716 pump body casting produced long after the '65 Model Year with a cast date code on the pump body perhaps. But if such a thing exists, it would not be an OE pump installed on a '64 or '65.
Old 07-05-2018, 12:56 PM
NYGTO's Avatar
Thanks John, I got hit for 5 points at the GTOAA Nationals this past week for having a non oem replacement water pump (from approximately 40 years ago). Now I'll get this and several other small easy issues straightened out. It was my first GTOAA event, great time from start to finish.
Old 07-05-2018, 01:29 PM
60sstuff's Avatar
Gary,
Find the correct 65 water pump and call -
Arthur Gould Rebuilders
Kings Park, NY
631-269-0093
I had them do mine in early 2015.
Extremely nice work!
Chris.
Old 07-05-2018, 03:11 PM
bill ryder's Avatar
He did mine in 1990, Chris. Guess I'm showing my age!!!!!!!!!!!
"Bill"!
Old 07-05-2018, 04:30 PM
or... you save some $$$, receive a top quality rebuild, and get in on the next build session
Old 07-15-2018, 06:56 PM
Slob4 Slob4 is offline
thanks to all foe the info reading the space between the fins and the divider!!!!
was having issues keeping the temp down so i took the water pump off today and wouldn't you know it - a 1/4 inch gap!!!! i followed the post and adjusted it down to .10 and the temp now does not go above 190 with all water !! thanks to all!!!!
Old 03-05-2020, 08:05 PM
elefantrider's Avatar
elefantrider elefantrider is offline
Anyone on the west coast who can rebuild these?
Is a 326 pump the same as 389?
Old 03-05-2020, 08:45 PM
Cardo's Avatar
Cardo Cardo is offline
The Dutchman is one of the best. Had him do mine. http://water-pump-rebuilders.com/contact.html
"I know just enough to keep me here, but not enough to get me out"
Old 03-06-2020, 12:09 AM
Thanks i wonder how much. They don’t list a price.
The rebuilt pumps from Ames are around $40.
Old 03-06-2020, 02:16 PM
Cardo's Avatar
I want to say it was in the neighborhood of $120..... Just remember ya get what you pay for.
Old 03-07-2020, 06:38 PM
Found a pump laying around my shop. Has a strange impeller. Will it work?
ID:	534022   Click image for larger version
Old 03-07-2020, 07:23 PM
Found another one. This one has a factory pn.
ID:	534024   Click image for larger version
