Old 04-26-2020, 03:53 PM
dhr1022 dhr1022 is offline
Default Safe spring compressor
Who has a good safe spring compressor that will work on a 65 Tempest, looking to change both front and rear and dont want to break the bank?
Old 04-26-2020, 04:28 PM
We've always found an auto parts store that will loan us one. In reality, you buy it and get a refund when you return it. It's the one that goes inside the srpring. We've changed the springs on ours a couple of times and never an issue.
The rears are fairly easy. No compressing needed. It's laid out in the chassis manual.
Name:	coil compress.jpg
Old 04-26-2020, 06:30 PM
Whichever you buy - lube the hell out of the threads.
Old 04-27-2020, 09:50 AM
78w72 78w72 is offline
& dont use an impact wrench...
Old 04-28-2020, 02:03 AM
connman connman is offline
On rear support the frame so there is plenty of room to lower the housing. slide floor jack under the housing with enough tension to take the lower shock mount off and lower down till spring is loose. Unbolt lower spring retainer. Note it's position. On front, remove the shock and support the frame with enough room to lower the lower control arm all way to end of "swing" or length of control arm. Remove the sway bar bushing at lower control arm. With the tire removed, put floor jack under the lower control arm as close to the ball joint as possible. Leave about 1/4" clearance for control arm/spindle to separate loosen the lower control arm nut about 2 turns . Take a "pickle" fork and wedge it between ball joint and spindle and separate. I use a BFH and turn wheel to get good hit on spindle where the ball joint is instead. It takes a lot of force to separate the ball join from the spindle!That way I do not risk tearing the rubber cover. There is no danger from spring until you take the nut off by jacking the lower control up just enough till nut can be unscrewed. Remove the nut and lower the control arm to the floor. The spring will stay in it's socket all way down! Remember that the control arm MUST be able to swing the whole 14" or so to the floor. No spring compressor needed to remove spring. Work safely and support car with proper jack stands .
connman
