Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Pontiac RA V tunnel port DS1200 heads and sheetmetal intake for sale
I just had these heads set up for a upcoming project that has taken a small turn.They are factory developmental 303 heads with 60cc chambers.They have been pressure tested and have had a complete rebuild with everything new.They are setup for a hyd roller cam with 150 on the seats and good for 660 lift.I will include all the removed pieces except for MAYBE on E valve and one spring seat.The machine shop is looking for them.I need to get $7900 for the package plus fedex shipping from 90814.You can PM or call or text me at 5622430570.Phone is on from 7 too 7 west coast time.Feel free to call with questions or other pics.Tom
more
even more
TTT
Still avail!Tom
These would be badass on the 326 short deck I'm building. Sadly, way out of my budget.
Jeff Ianitello |
Too big of valves anyway!Needs at least 4in bore.Tom
What block are you going to use?Tom
Its a 301T block, 4bolt mains (7/16 outer studs), building a block girdle for it. Filling it up to the bottom of the freeze plugs. Going to be 4.030". Using a 316 forged crank, 3.25 stroke, that was welded up for 3" mains. Eagle 6.250 HRJ rods, superlight Icon pistons. Solid flat cam, RA4-ish specs on a 112, roller rockers, stud girdles. Right now have a set of 48s that have been ported. Dont know what they flow, prob 240-250cfm. Cut down TQII with runner extensions added in the plenum, plenum divider, 1" divided (or open) spacer, 750 Edelbrock
Jeff Ianitello Last edited by pontiacjeff; 06-14-2020 at 03:38 PM. Reason: Add info |
326 (331), 7000rpm street engine, 4sp, 4.11 gears, 77 Astre Formula.
Jeff Ianitello |
They would work with the 301 bore but still tight.Are you on board with the hybrid head gaskets from Joe?Are they welding up the thrust also?Tom
spacer on block side?Tom
The thrust was welded up. This crank is beautiful. I have not had the rods turned down yet, but will keep it 3.25" stroke.
I am using Program billet caps and will machine the cap for the 400 thrust bearing. The cap (and the crank) will keep the upper bearing from moving. Not planning to use a bearing spacer. I have heard about the (Cometic?) head gaskets, but don't know who has them. Do you have contact info? Thanks.
Jeff Ianitello |
They are not Cometic,they are SEC.I think they have to be bought from Joe.I have my set.PM me a cell number and will send you a pic.Tom
SCE!
Still looking for a home!Tom
New price.$7500 but the used valves,springs and retainers are no long avail.Tom
TTT
TTT
$7250 without the carb!Tom
