Old 05-29-2020, 02:20 PM
dld's Avatar
dld dld is offline
Originally Posted by tempest1964 View Post
Who did you get your springs from dld?
Put a set in from Detroit Spring . They were way to strong. Car sat 2" to high. had conversation with them they said they were correct . Just drive car 50 miles or so it would set . $60.00 shipping both ways for another set . I explained i don't drive this car . Well I took them out and put the old stock springs back in but installed a rubber spacer on top of spring so not to be seen . understand a 1/4 or 1/2 at spring pocket is multiplied buy the length of lower control arm. Don't have the formula but about double
Old 05-29-2020, 03:47 PM
Tom Vaught's Avatar
Boost Engineer
I bought some springs from Detroit Spring that did the same thing.
They said they were a OEM supplier. OK, your stuff still isn't right.
Took them back out and installed some oem spacers like you did with the Pontiac springs and all is good.
Tom V.
Old 05-29-2020, 05:39 PM
6t5gto 6t5gto is offline
This is with the new correct springs. Before it looked like I was going 4 wheeling.
ID:	541326   Click image for larger version
ID:	541327   Click image for larger version
Old 05-29-2020, 07:59 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Originally Posted by dld View Post
Hi, Bill
I really didn't see the method they used but showed up on score sheet. It was my first time out . GTOAA in Monrowville PA. I was a little overwhelmed buy events being a newbee . Since then I have learned a little more about the process. As i'm sure you have also.
I was there with my 65 post (outside). I remember looking your car over, it's gorgeous . Stop beating yourself up. Just get in and drive it as much as you can ,you will feel much better. LOL
CRAP ,I don't know how to fix the picture
Old 05-30-2020, 02:43 PM
dld's Avatar
dld dld is offline
yes, i remember your car also. but it was on its wheels ....nice.
