Old 09-10-2020, 07:18 PM
67428HO 67428HO is offline
Default 68 GTO power antenna
Hi, Are the power antennas different from 66-69? How can you tell the difference? Thanks!
67428HO
Old 09-10-2020, 10:46 PM
kk68's Avatar
kk68 kk68 is offline
Yes, but I think the differences are subtle. Here are a couple shots from the Restoration Guide with some explanation.
ID:	549207   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 09-10-2020, 10:53 PM
kk68's Avatar
Here are a few pics of my 68 convert pwr antenna. Mounting flange and bezel is at different angle on convertibles than hardtop for 68-69, but I think that’s the only difference.
ID:	549209   Click image for larger version
ID:	549210   Click image for larger version
68 GTO convertible
C1 224 Triple white
Old 09-10-2020, 11:50 PM
As seen in the picture in the first response to the thread the 68-69 antenna bodies are shorter than the first gen ones. Because the lower bracket has no set position you can make any A body antenna work in a 68-69.
Note that the B body antennas have much longer body and can’t fit in an A body and inversely the rare 69 fbird Power antenna Is much too short.
My GTO ragtop has its original convertible unit and my LeMans ragtop has a 69 coupe unit. As viewed from outside they both look identical but if you look inside the convertible one has the motor cocked 90 degrees differently and so the coupe one doesn’t have the upper adaptor sit quite flush against the inside contour of the quarter panel but this doesn’t matter once installed.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-13-2020, 03:43 PM
joe'sgto's Avatar
joe'sgto joe'sgto is offline
Picture on my 68 power antenna
Old 09-13-2020, 04:41 PM
I believe the convertible unit installs 90 degrees more clockwise as viewed from above.
1969 Bonnie Cvt
Old 09-13-2020, 09:28 PM
I was told it was a 66 model and was hoping to use it in my 68. Thanks
67428HO
Old 09-13-2020, 09:37 PM
Scott Thelander's Avatar
the date is stamped in the round side cover
