Headers size
Hi: What size headers would be required to support a 750 hp engine? Round port.
Looking at a set of Doug's 1-7/8" for a 68 Firebird. Also wondering if they will fit a 68 Firebird? Thanks https://butlerperformance.com/i-2445...tegory:1234810 |
Here's some base line info for you.
The main concern before Exh flow numbers though is that the inlet to the header tube is bigger then the Exh port outlet flange size by atleast 1/16" and preferably 1/8", especially on the floor of the port which is not a issue if the round ports are the better working D shaped version . How many cid is the motor?
That graph os useless in my opinion. If you follow that graph then ci and rpm jave nothing to do with exhaust size. According to that graph our GTO should be running roughly 1 3/4" headers, the car was 2tenths slower with that size header vs 2".
Chuck I am running 1 7/8 on my pos
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
That's probably the problem
Personally I think 1 7/8" headers are going to be marginal for 750 HP. A few years back I dyno'd a ~ 550 HP engine that was 461". We initial used 1 5/8" headers because he was going to use Ram Air manifolds on it in the car and we thought they would be similar in flow. After getting a base number, we swapped to 1 3/4" headers and the engine picked up 18 HP. I think at 750 HP you would be giving up some power versus 2" tubes. Just a fyi, I recently built a 535" that made 872 HP and we used 2" headers. Myself, I run stepped headers 2 1/8' to 2 1/4". Engine made 1039 HP
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I don't know how useless it is but that formula posted above was published by David Vizard. As many know much of his work has been centered around Chevy engines, especially the 350cid. Therefore I've often wondered if it might be canted in that direction.
That said I've taken note of it and worked the formula around my Edelbrock heads and with porting the exhaust port ended up towards 250 cfm at the upper lifts. As noted David's formula is based on the INSIDE diameter. I run 2-inch headers (outside diameter) on my 505 that makes peak power at 6000 rpm. Here is another one below that tends to back that up. How Header Primary-Tube Diameter Affects Performance ? Tech article from Hot Rod magazine: https://www.hotrod.com/articles/head...s-performance/ 2-inch outside diameter less a typical wall thickness. Example- 16 guage = .062" x 2 = .124 or 1.876" inside .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 09-30-2019 at 10:17 AM. |
You reply that way every time I post up that info slowbird so why don't you post up your guide lines and be more helpful.
Buy pipemax, very cheap software, tons of info, and will not lead you down the wrong path. No header builder that i've talked to has ever asked me for exhaust flow numbers.
The thermal dependancy is CSA & Length dependent. These tings show up as EXH velocity vs travel length. Id be keen to see a plot of EXH dia vs RPM for best ET. Could be an eye-opener. |
Thanks guys..
Charles |
I like the Wallace racing calculators.
