Old 11-11-2020, 11:37 AM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
Default New best
3710# with driver
ID:	553628   Click image for larger version
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
Old 11-11-2020, 11:47 AM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Congratulations. Very nice pass.
mysticmissle's Avatar
nice sweet car!
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-11-2020, 12:51 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Congrats Jeff!
Chris D
Old 11-11-2020, 12:58 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Congratulations!!!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 11-11-2020, 01:42 PM
chuckies76ta's Avatar
Wow, awesome times. Beautiful car also.. What kinda H/P?
Old 11-11-2020, 02:19 PM
Scott Stoneburg's Avatar
Sweet looking ride. Congrats on the new best
Old 11-11-2020, 04:38 PM
Congrats!
Nice pass. Car reminds me of Kelvin Poe's old race car.
Very good looking car.
Old 11-11-2020, 04:41 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Very, very nice. Congrats
Old 11-11-2020, 05:10 PM
Dragncar Dragncar is offline
Thats a nice pass. 1.39 60 foot at your weight and almost 135 MPH !!
Combo ? Stock block or aftermarket ?
Old 11-11-2020, 08:29 PM
Thanks everyone for the kind words.
MR1 block with HP heads and NW intake.
535 Street driven
Old 11-12-2020, 12:04 AM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
Nice car and pass
Kevin
Old 11-12-2020, 12:47 AM
535 Street driven
Pump gas ??
Old 11-12-2020, 02:15 PM
Pump gas ??
Yes, 93 on the street but I use 110 at the track for a safer tune. Around 11.1 comp
Old 11-12-2020, 02:21 PM
Northwind intake. Are you using a Doninator?
Carb size ?
Old 11-12-2020, 02:39 PM
Carb size ?
1100 Pro Systems Dominator
Old 11-12-2020, 04:12 PM
Thank you
Old 11-12-2020, 05:40 PM
Nice ! I am build a pump gas engine right now that should see a dyno. I plan on initially running some mix or booster at first and then switch to PG and see if the power drops and go from there. I will be around 11.25-11.40 CR.
You heads, what have you done to them ? I am running High Ports also with mild port job and will run a 1150 Pro Systems carb.
