Old 02-22-2020, 10:24 AM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Cleaning radiator out
So I stumbled upon a little problem. I'm in the process of building a rat rod and am using my old Harrison 4 core radiator from my GTO. Today i removed the cap and found the upper tank is full of mouse nest material. Ive stuck a vacuum over the hole and it sucked some out but it seems theres still a lot in there. Any advice on how to get this out? I'm thinking i may end up taking it to a radiator repair shop if I can't get it out.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 02-22-2020, 10:40 AM
78w72 78w72 is offline
maybe try to flush it with compressed air or water from the bottom tank while turned upside down? worth a try before paying someone to get it out.
Old 02-22-2020, 11:09 AM
455rebel 455rebel is offline
Let it dry, burn it, then blow out the ash?
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 02-22-2020, 02:36 PM
242177P's Avatar
242177P 242177P is offline
Pull rad, turn upside down, fill rad through bottom outlet (now top) while
holding your hand over the top inlet (now bottom outlet). Remove hand,
should get a slug of debris. Other than maybe having to manually pick at "log
jams", it should all come out without any drama. Repeat until you're satisfied
Old 02-22-2020, 10:08 PM
67gtospud's Avatar
Flushing the radiator from the bottom to the top worked perfectly. Thank you to all for the suggestions and help!
