OHC-6 TECH Over Head Cam projects, questions and advice.
Old 06-14-2012, 10:20 PM
bluegoose66 bluegoose66 is offline
Default 1967 sprint questions
I just purchased a 1967 Le Mans sprint with no motor no trans. Was going to put in a v-8 figuring it would be easier to find . But I found a sprint 6 complete running from a firebird with a stick trans and radiator. The car has the frame mounts,exhaust and z-bar. Will I have to change alot of parts to make it work? Just new to the sprint thing. Thanks Bluegoose
Old 06-15-2012, 12:44 AM
Formulabruce's Avatar
should be easy..especially if the 6 has its engine side mounts still. The frame mounts will be a bit different but easily had.
sprints are way cool. Im trying to get a convertible sprint myself
Old 06-15-2012, 01:02 AM
Default engine
Just Remember to take lots of pics of the Firebird so when it's going into the Lemans it looks the same as it did in the Firebird. Take your time & pay attention to where things are comng from & then put them back in the same way & you should be ok. We learned the same way your going to know, by DOING. Rex.
Old 06-15-2012, 05:46 AM
Jeff Hamlin's Avatar
If the car was a OHC model and never had any changes/mod's then it should be a straight forward install.
As stated you will need the A-Body engine mounts (shown below)
as well as the OHC engine frame brackets.
The F-Body mounts & Brackets are diff.
IIRC the Z is also diff for the A-Body.
Best of luck.
Old 06-15-2012, 08:51 AM
Cammer-6 Cammer-6 is offline
throttle cable and bracket are different too
if the Sprint motor is a 68 you will have trouble with fan clearance
(Ask how I know )
also radiator is different so just buy a new one
I would go with a 3 core to make sure it stays cool
where are you located?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-16-2012, 11:24 PM
Default sprint
Why does the fan not fit? Do I need different water pump or the fan itself ? The Le Mans has some of the parts in the trunk.
Old 06-17-2012, 10:43 AM
68-9 used a spacer for fan because of larger balancer.
this is very close to bottom of radiator when used in 66-7 body
Firebirds and 68 and newer A bodys had plenty of room
my fix was to have the 67 balancer bored and cut to fit the 250 crank
Old 07-23-2012, 12:19 AM
Did anyone come up with a motor they are interested in selling.
Old 07-23-2012, 06:14 PM
look in the newly formed OHC-6 classifieds
Old 08-16-2012, 10:34 PM
Default thought i had one today .....
I drove a hundred miles one way today to pick up ohc 6 motor. I get there it had HEI distributor and oh ya looked like straight 6 out of a chevy pick up. Not a happy camper to say the least.
Old 08-17-2012, 05:47 AM
robscar's Avatar
robscar robscar is offline
Where are you located?
I have a complete 68 zd motor I am not going to use. However, I am in south central Pa.
