Old 08-04-2023, 10:45 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
Default Overheating solved 67 Firebird 400
My 67 Firebird 400/TH400 factory 3 core radiator would not cool! It would run 190-220 deg. and sometimes hotter regardless of what I did. I installed a Cold-Case #CHC11A aluminum radiator, and all the problems are now solved. This CHC11A has 42 rows of two 1 inch cores. The stock 3 core had 27 rows with 3 - half inch cores. That's 15 more rows with more cooling capacity. The Firebird now runs 165 on the road, and 170-185 in hot Florida traffic. I run a 160 thermostat and a non thermal, 7-blade, 19" clutch fan. I painted the outside perimeter tanks with Eastwood radiator paint to give it the stock look, and left the center cooling fins unpainted for better heat dissipation.
The Following 4 Users Say Thank You to Doug Hopkins For This Useful Post:
Old 08-05-2023, 12:23 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Great news! I run a Cold Case in my 1979 400.
Your previous rad was the ORIGINAL factory radiator? Odds are good it was clogged up, too. I don't care how well maintained it may have been. A 50+ year old part is a 50+ year old part.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 10-04-2023, 09:27 AM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
How is the fit compared to the original radiator? Any mods needed?
Old 10-04-2023, 10:11 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
My guess would be it dropped right in. Cold Case seems to have the process down.
I run a replacement Cold Case in my 72 LeMans GT. Perfect, drop in fit.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
