Old 11-18-2020, 03:22 PM
slowbird's Avatar
slowbird slowbird is offline
Default What will it make?
Building a new engine for our 69GP. Just curious what people think it'll make.
Its a 11:1 463ci with a 242-247 HR cam .640 lift, kre d-port heads flowing 320+in 230+ex (2.11x1.77 valves), topped off with a RPM intake and 950Holley and1 3/4 headers.
Old 11-18-2020, 03:24 PM
tom s tom s is offline
Old 11-18-2020, 06:54 PM
pastry_chef's Avatar
Any work to the RPM intake?
Old 11-18-2020, 07:03 PM
slowbird's Avatar
Port matched and blended for the square bore carb.
I will add there is nothing special/trick done in the short block
Old 11-18-2020, 07:33 PM
ta man ta man is offline
600plus..I like the compression ratio. Any more details on the head/cam combination?
The Following User Says Thank You to ta man For This Useful Post:
Old 11-18-2020, 07:38 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
575hp. Would be my guess.
Old 11-18-2020, 07:59 PM
ponjohn's Avatar
ponjohn ponjohn is offline
605 / 635T
Old 11-18-2020, 08:12 PM
Tom Vaught's Avatar
Boost Engineer
635 hp
Tom V.
Old 11-18-2020, 08:35 PM
chuckies76ta's Avatar
600 hp 600 t
Charles
Old 11-18-2020, 09:58 PM
i82much's Avatar
i82much i82much is offline
don’t wanna pee in your wheaties but thought i heard the rpm might have a lean cylinder or two in applications pushing that kind of power. maybe try a T2? or at least do a forum search to see if you find any info on that issue.
Old 11-18-2020, 10:17 PM
4dblnkldude's Avatar
I'll play...I say 622
Old 11-18-2020, 10:31 PM
slowbird's Avatar
Not worried about it. But we will be testing a couple intakes including a tri-power.
I sure hope some of you guy are right but i think there are a lot of optimistic guesses here.
Old 11-18-2020, 10:32 PM
slowbird's Avatar
Like?
Old 11-18-2020, 10:36 PM
Hmmmm…… Nice donuts
Old 11-18-2020, 10:37 PM
i82much's Avatar
ok cool. if you decide to post the results i will definitely look forward to seeing them.
Old 11-18-2020, 10:39 PM
Steve C. Steve C. is online now
A related combination for interest....
SD Performance KRE D-port 300-305 cfm CNC ported heads.
10.5:1 compression ratio
Comp part # 51-000-11
Grind # P8 3115B / 3116B HR112.0
.006" - 306 / 314
.050" - 246 / 252
0.4000" lobe lift intake & exhaust / 1.52 rocker ratio
112 LSA
Crower solid roller lifters w/ .005" lash
Minimum 150 lbs seat pressure after run in
.030-over 455 / 4.250" stroke
Torker II intake port matched to the heads w/1-inch open carb spacer
Holley HP950 carb
1.75 headers
588.5 HP at 5800 rpm
600.6 ft.lbs. torque at 4600/4700 rpm
Old information here:
Old 11-18-2020, 10:55 PM
Like?
Yes..great compression for those heads ..should have no issues with pump gas.
Old 11-18-2020, 11:05 PM
firechicken's Avatar
firechicken firechicken is offline
Looking forward to results.
Thanks for sharing.
Old 11-18-2020, 11:36 PM
My 455 with 290 heads and 10.25 CR with stock type dual plane intake and a 750 carb made 550 with a touch more cam.I figure the Xtra CI,better heads,more CR,better intake and bigger carb should get him above the 600.Tom
Old 11-19-2020, 01:51 AM
i82much's Avatar
I am curious whether you are considering beehive springs and lightweight retainers? have read some about getting more high rpm power that way.
