Old 10-03-2019, 03:23 PM
dataway's Avatar
dataway dataway is offline
Default Where does this Hideaway bracket go?
Pulled this off a 69 ... don't see it in the mechanical diagram of Hideaways.
68 and 69 or just 69?
Old 10-03-2019, 03:43 PM
1969 Ram Air 1969 Ram Air is offline
Default Bumper
Right where the bumper brackets attach to the bumper. This diagram shows both brackets.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 10-03-2019, 04:10 PM
dataway's Avatar
Excellent, thanks ... so it reinforces the jack point? Not that I would ever use that jack point
Old 10-03-2019, 04:15 PM
gto4evr gto4evr is offline
yes, it's for reinforcing the jack point. both 68 and 69 use it in both standard and hideaway noses.
you got it, NEVER use your bumper jack x 50!!
Old 10-03-2019, 09:09 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
I installed them, and all I can say besides the fact that you can't see them, is they get in the way for fine tuning the adjustment of the bottom grill bracket. Seriously thought about taking them back out for that reason alone....
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 10-04-2019, 02:20 AM
Before I realized that the folks here were correct in their assessment that they are there to provide support for the bumper jack, I noticed that they also provide needed support for the inner plastic grilles right where they meet the headlight doors. Without those pieces in place, you could easily push the flimsy grilles in to the breaking point there.
Old 02-10-2020, 09:42 PM
Tim68 Tim68 is offline
I am in the process of removing my front bumper and found that these were welded to the bracket they are bolted to.
I had to grind off the welds to remove the bumper.
Old 02-10-2020, 10:38 PM
Scott Thelander's Avatar
bummmmmmmer
welcome !!
Old 02-11-2020, 03:40 AM
dataway's Avatar
I'd say on GTOs ... besides the engine .... the Endura with Hideaways is the most horribly modified and backyard engineered piece on the car.
I've seen all manner of terrible "fixes" on them.
Check to see if the bumper is tweaked ... I'm guessing someone couldn't get the bolts back in because of alignment issues. If you are lucky they just lost the bolts and decided to weld them.
Old 02-11-2020, 03:56 PM
68ragtop's Avatar
I would agree. Out of all the surface area on My 68, I have spent way more time per square inch on the front bumper than any other area of the car. Probably even at 4x the amount of time. Not just paint and prep, but getting the thing to fit, tweaking, modifications, etc. Even in final assembly after all was painted, its still took more time to fit than any other panel. The slightest movement at the attaching points, is greatly exaggerated where it meets the bumper.
89 Trans am GTA
Old 02-11-2020, 08:37 PM
68ragtop's Avatar
Oooops, I meant were the bumper meets the fenders.
89 Trans am GTA
Old 02-12-2020, 08:05 PM
Have NOT ever kept those on my 68's (4-decades worth) and scarcely recall ever seeing them on most 68's
