Old 02-12-2020, 10:34 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up Head Gaskets
How many of the Higher Compression motors, and or Boosted use SCE Copper Head Gaskets. I have been using Cometics at 14.6-1 Comp. I was thinking of switching to the SCE Gasket. Are these re-usable? Being an Aluminum block and head deal,I thought about switching over to the Copper Gaskets.
Old 02-12-2020, 05:33 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
I'm using SCE 0.080 with double O-rings. I've reused 1 head gasket after dropping an intake valve.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 02-12-2020, 07:09 PM
GTOGEORGE's Avatar
I have the ones with the built in SS o-rings in them, they seem to be OK.
GTO Gey
Old 02-12-2020, 09:29 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
Flatout has rubber coated copper gaskets for Pontiac. Has anyone used these?
Old 02-12-2020, 09:34 PM
mgarblik mgarblik is offline
Yes, we have been using the coated copper gaskets from Flatout for over 20 years. The Boss Bird has the original set of head gaskets we put on in 2010. Zero leakage, they have been on and off the engine at least 20 times. They have drawings for many Pontiac gaskets. Highly recommend.
Old 02-12-2020, 11:01 PM
slowbird's Avatar
slowbird slowbird is offline
Curious are you seeing issues?
Im around 16:1 with Cometic and havent see any issues yet with my HP heads. My dad has seen some water leaking on his but his e-heads have thousands of runs (been running since 1995) so i think the issues we are seeing are from the heads being used up.
Old 02-13-2020, 09:33 AM
I was thinking better Sealing with Copper as Temperatures change. More consistent Heat distribution In the Combustion chambers. No Issues with Cometics so far. I feel the benefit to the Copper Gasket is that it is more uniform being 1 solid piece VS Multi layer Gaskets.
Old 02-13-2020, 09:44 AM
Does the Flatout Rubberized Gasket Need O-Rings in the Head and or Deck? SCE sells a Copper Gasket that doesn't require using O-Rings. I have 2 sets of the Flat out Gaskets. However the Bore size is 4.250" I need 4.380".
Old 02-13-2020, 09:52 AM
Scott Stoneburg's Avatar
I'm interested in the last part of your statement about the heads being used up. I can understand the valve guides or seats wearing over time. But what would wear out and cause water to seep?
Old 02-13-2020, 10:52 AM
bad69bird's Avatar
bad69bird bad69bird is offline
I'm using the SCE copper gaskets with no issues. Whether or not I re-use them, depends on how many passes I have on them.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 02-14-2020, 12:05 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
What about the Marty rings? Has anybody tried them?
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
The Following User Says Thank You to jimmy daniel For This Useful Post:
Old 02-14-2020, 12:06 AM
I know Frank at All Pontiac uses them on his motor.
Old 02-14-2020, 12:09 AM
slowbird's Avatar
Years and years of abuse, been over heated probably a dozen times. In my opinion the alum just isn't as hard as it once was (maybe lost the heat treat?), seem softer now.
Old 02-14-2020, 07:32 AM
If I am not mistaken Brodix offers a retempering service for all heads, not just there own.
If you have expensive CNC heads then it's worth the rebuilding cost that will be needed after treatment.
Old 02-14-2020, 10:19 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
FWIW We recommend the Cometics for your combination. Gasket built to your specs...no extra machining, Cost effective, Supports lots of HP, Simple & Easy. Unless there is something else going on that we are unaware of.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 02-14-2020, 06:17 PM
Ok. I see what you mean. Thanks.
