Vacuum pump choices
Thinking of adding a vacuum pump to my IA motor.
GRZ, Star, Moroso-pros cons to the different ones. Car wil nto be getting lots of runs just a few outings a year.
I just took mine off, I drive more on the street and go to the track a couple times a year. I have it adjusted down about as far as I can and if I drive any distance like 100 miles or so It will fill the tank and oil will come out the top vent. So if you drive any distance keep an eye on it.
Ive heard good reviews about the GZ pump. Also looking at the AeroSpace pump. I know a couple people working there as they are local to me.
I use a Star Machine sportsman pump..SD provided the pump, mandrel, catch tank,fittings, hoses, belt brackets and bolts . It works well pulls a good vacuum..I may get an ounce of oil after a 200 mile round trip and a few passes at the track.
A 200 mile trip will spray oil down the side of the car. At 60 - 65 on the highway it pulls about 8" of vacuum and the relief valve is adjusted all the way out.
Are you running a dipstick?
1969 LeMans..Liberty Blue 2001 WS6..Sunset Orange 1973 Pro Street Firebird..Lucerne Blue |
Ok, star machine on my 535 street/strip with no issues
GZ best pump out there IMO
Cylinder Head drainback issues? Sorry for getting off track. I just installed for this year the Moroso enhanced 4 vane. Nice piece. Pulls vac immediately. Mandrel and pulleys from Butler. I got good deals on the tank and hoses from Amazon.
Star best pump out there IMO
Second best is Moroso IMO |
Thanks guys.
I agree! You pay for it ,but they rock!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
Any pictures guys? Esp. a second gen F body.
My pump gas setup
Can't go wrong with a moroso pump. It will pull as much vacuum as you need or more then you need. All depends on how good engine is sealed up.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Pulling from a valve cover breather like header vac breathers with a baffled grommet OK or pull too much oil?
That was how I did it at first... never had a problem with it that way.. I personally just never liked the way it looked, so I welded in a bung. Chad
3500lb 10.5" tire. 5.34@134.4 with a poor 60' |
Here is a fun question....
How much vacuum is every one pulling? In my car on the analog gauge I'm right around 15 " at the stripe... on the dyno with a transducer (digital sensor) it was only pulling upper 7's... Now I have put a grid module to record it during the run on the track and it is reading the same as the dyno... 7.8-7.9" at the stripe... So I'm guessing the analog gauge is incorrect.. Just wondering if anyone else has checked this? Chad BTW gzmotorsports 104 pro pump
On my street car I run the modified Butler version , I think it was a converted smog pump. One valve cover plugged, pulls from the other side to a moroso breather tank. Has always worked pretty well
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
Thread Tools | |
Display Modes | |
