Old 11-15-2019, 08:58 AM
7T-GOAT's Avatar
7T-GOAT 7T-GOAT is offline
Default 69 GTO convertible Deluxe bucket seat belts
I'm upgrading my seat belts in my 69 GTO ragtop from standard to the deluxe brushed stainless. Ragtops only get one buckle per bucket seat, as apposed to two on a coupe. Couple questions...
Are the bucket seat deluxe buckles and their male ends the smaller size?
Also is the buckle (female end) attached to a non-adjustable belt?
What's the over all length of the female belt, anchor to buckle?
Pic shows both types of seat belts...Thanks
Old 11-15-2019, 10:01 AM
kk68's Avatar
kk68 kk68 is offline
In your photo, the larger buckles look like the bucket seat lap belts which are paired with the retractable males. The smaller buckles look like they are for the shoulder belts.
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 11-15-2019, 10:09 AM
7T-GOAT's Avatar
Default Deluxe belts
Yes I understand that. But for some reason (I've been told and seem to remember) that when you have a convertible that came with deluxe belts, the bucket seats took the small buckle and the rear bench seat took the larger buckles. I'm trying to confirm if this is correct.
Old 11-15-2019, 10:33 AM
Brewster's Avatar
Brewster Brewster is offline
My 69 car has small up front with bigger ones in the rear seat. Dont recall without looking about retractables?
Old 11-15-2019, 10:40 AM
7T-GOAT's Avatar
Mark Simiele's back seat. I sent him a pm to find out what the front buckles look like.
Old 11-15-2019, 11:47 AM
gto4evr gto4evr is offline
the small buckle deluxe belts for the front are on locking retractors hence non adjustable straps. The rear belts are the bigger buckles with adjustable straps
early 69 deluxe retractors had a knob on them to lock the retractor, later 69 was a self locking retractor without the knob.
Old 11-15-2019, 06:34 PM
7T-GOAT's Avatar
Good info gto4evr, thanks. I can't find any pics of this set-up. Any pics out there?
Old 11-15-2019, 07:54 PM
Here is my 69 LeMans ragtop. In the first pic you can see the small buckle for the driver and right passenger that connect to the self adjusting retractors. The tongue (male) you see is for the optional shoulder belt (they are reversed on a ragtop-buckle outboard).
The rear lap belts (and the center front on bench seat application) use the manually adjusting larger buckle-tongue units. Note that these larger deluxe tongues are not interchangeable with the non-deluxe ones, they have a different shape and won't work properly if mismatched.
On convertibles with optional front shoulder belts (they were offered with or without deluxe belt option) the tongue bolts inboard at the driveshaft hump and the buckle bolts to the top frame mounting bracket, there is a small keep that bolts onto the rear armrest to keep them from flying around when not in use.
ID:	524573   Click image for larger version
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 11-16-2019, 04:44 PM
7T-GOAT's Avatar
Then small deluxe buckle it is. Thanks North and the rest of y'all.
Old 02-23-2020, 12:26 AM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
Tom, my apologies. Haven't been on here for a few months and just saw this. It looks like you found out what you needed. If you need help with front seat photos let me know. Hope you got the belts in with no issues.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
