Old 03-31-2018, 04:48 AM
Hikin Mike's Avatar
Default 1969 Firebird TH400 Kickdown Switch
My car has never had a kickdown and I'd like to finally install one. I know I can get the bracket/switch via eBay, but not sure how it mounts/connects. Can somebody take a photo of the TH400 kickdown switch mounted on Quadrajet?
Thanks!
- Mike
Old 03-31-2018, 10:08 AM
68tpls400 68tpls400 is offline
Try these:
ID:	479502   Click image for larger version
Old 04-01-2018, 04:22 AM
Hikin Mike's Avatar
That's odd, I replied earlier but I don't see it.
Thanks but I my carb has a different linkage (73 Buick 800). I'm not seeing the plug in my engine compartment either.
- Mike
Old 04-01-2018, 06:30 PM
Ron Landis's Avatar
Default Good picture...
Originally Posted by 68tpls400 View Post
Try these:
and I believe that these are available aftermarket (B&M) if function is all you're after.
Old 04-02-2018, 01:08 AM
Hikin Mike's Avatar
Yes, at the end of the day I just need it to work. But like I said, I've been driving it like that for years, just figured I'd add one. I've got a switch/bracket that mounts to the gas pedal. Used to have hooked up but for some reason I removed it. Need to find it in my stash.
- Mike
Old 04-04-2018, 08:24 AM
grivera's Avatar
grivera grivera is offline
I use the Lokar set up - top notch!!
https://www.summitracing.com/parts/c...0082/overview/
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 04-06-2018, 03:13 AM
Hikin Mike's Avatar
Thanks, but that is WAY out of my price range.
- Mike
Old 06-22-2018, 10:05 PM
92GTA's Avatar
92GTA 92GTA is offline
Try just this, it's all that I needed:
https://www.summitracing.com/parts/l...400u/overview/
Old 06-23-2018, 12:20 PM
Hikin Mike's Avatar
I ended up finding and re-installing the kick-down switch I bought at wrecking yard 25+ years ago.
- Mike
Old 06-23-2018, 12:40 PM
Old Goat 67's Avatar
That's all you need, except Please cover those bare terminals with sumtin.....
Old 06-23-2018, 12:49 PM
Hikin Mike's Avatar
What bare terminals?
- Mike
Old 06-23-2018, 01:19 PM
cnc's Avatar
cnc cnc is offline
I think he is talking about the terminal "ends" on the wires.....where they plug onto your switch...shrink tube works perfect for stuff like that
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 06-23-2018, 02:39 PM
Hikin Mike's Avatar
That's what I thought. I added shrink tube.
FWIW, my background is in electronics.
- Mike
Old 06-23-2018, 05:14 PM
Uh huh, messing with us........
Old 06-23-2018, 09:57 PM
NeighborsComplaint's Avatar
That's all that is needed with a TH400. You don't need a TV cable or that overpriced Lokar stuff.
Old 06-23-2018, 10:50 PM
Hikin Mike's Avatar
I don't drive it much. A few days ago I forgot I had installed the kick-down switch. I got on it and "Wham". I was like, "What the heck was that....oh yeah, I remember now"...lol!
- Mike
Old 02-19-2020, 01:45 PM
grivera's Avatar
Reviving old thread -
I'd like to add the factory kickdown to my 69 but it doesn't have the bracket under the gas pedal to add it - where does one get the bracket?
ID:	532457   Click image for larger version
ID:	532460   Click image for larger version
Will Rivera
Old 02-19-2020, 04:59 PM
Hikin Mike's Avatar
The stock kickdown is mounted on the carb (not my picture).
- Mike
