Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-08-2020, 06:40 AM
mysticmissle's Avatar
Originally Posted by slowbird View Post
Valve sizes?
How much?
Valve sizes are 2.25x1.75 on the Knowlton set, they have better hardware w ti valves Pac springs ti retainers.
SD set has 2.25 1.74 SS valves and comp springs and hardware. I found the SD sheets i wwill post later, the heads are very similar in flow and quality, only difference being top hat head bolt washers, chamber size and valve material.
Prices have not changed
knowlton thunder heads Ti valves 64.5cc chambers. these will be priced at $4800 with single plane intake of your choosing and the 1.6 shaft set up. These are fresh from H&M no cam, push rods or lifters included, but still available if you are interested in that as well
72 cc SD edelbrock wide ports with sheets 225I 1.74E (372@.750 range) have not reviewed them in awhile
t&d 1.6
push rods, head studs w top hat washers
SD ported victor intake or
BOP wide port intake port match no plenum work
Comp roller cam standard journal .479x 4.6x lobe 113 lsa
crower bronze bushed 842 lifters
$5000. heads and lifters about 80-100 passes since fresh
also have 1050 gas dominator available $500
all prices plus shipping, will include a set of intake gaskets with heads to make them pretty much bolt and go
I am really close to bolting one pair on, and have no problem keeping both sets. Thanks for Looking
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-18-2020, 01:10 PM
no longer available thanks for the opportunity Ames. Please delete or Move Mods
1964 540 gto
