Old 12-21-2019, 07:50 PM
bober bober is offline
Default 455 (30 OVER) 462
The block # is 485428, 455 bored 30 over (462) completely rebuilt / Line bored/Honed/0 Deck and squared! Internal Parts as follows: SP.030 TRW L 2359 FORGED PISTONS ON RPM FORGED I-BEAM RODS W/ 7/16 ARP CON ROD BOLTS ! COMPLETELY BALANCED WITH NEW HARMONIC BALANCER AND NEW HAYES FLEX PLATE! THE (6X4) HEADS HAVE BEEN TOTALLY REBUILT AND MACHINED FOR POSITIVE VITON SEALS ALONG WITH ENLARGING THE EXHAUST VALVES TO 1.77 /2.11 INT. (STAINLESS STEEL) ! THIS SHOULD END UP WITH A COMPRESSION OF APPROXIMATELY 9.5 TO 1 ! ALSO HAS ALL NEW SPRINGS/ROLLER TIP ROCKERS AND NEW PUSH RODS . THE ONLY PARTS THAT HAVE BEEN REBUILT AND NOT (NEW) IS THE 850 CFM Q/JET AND THE ORIGINAL 455 CRANK THAT WAS RESIZED AND POLISHED ! (NEW BUTLER ) (6 QT ) OIL PAN /DIP STICKS/TUBES W/60# PUMP AND 1 PIECE OIL PAN GASKET /VITON CRANK SEALS./ (RARE) EXHAUST MANIFOLDS. WITH MANDREL BENT DOWN PIPES (FIT 2ND GEN BIRDS AND MANY OTHERS) I ALSO USED THE 1972 STOCK CAST INTAKE FOR EX FLOW AND CORRECT HOOD CLEARANCE FOR FIREBIRD ! THE CAM I USED IS A ELGIN E 980 P /I HAD A 979 IN A PREVIOUS 462 IN MY 76 BIRD AND IT WAS VERY STRONG SO I BUMPED IT UP 1 MORE # ! STILL POWER TO BE MADE WITH UPGRADES TO CAM AND ALUM HEADS WITH A BOTTOM END TO HANDLE IT !!!!! THE PICS SHOW THE ENG . PLEASE LOOK IT OVER AND GET BACK TO ME WITH ANY MORE INFO AS NEEDED, THANKS FOR LOOKING
Here's some specs related to this engine !!! 5500.00
Old 12-24-2019, 02:21 PM
57Chief 57Chief is offline
Bobber
Could you call me, I would like to talk to you about your 462.
Scott
31nine-67seven-zero579
Old 01-05-2020, 10:14 PM
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX BUMP
Old 01-25-2020, 11:52 PM
BUMP
Old 02-13-2020, 07:49 PM
This is AVAILABLE XXXXXXXXXXXXXXXXXXXXXX PICK UP AVAILABLE ONLY ( 4900.00)
Old 02-14-2020, 04:36 PM
roy381 roy381 is offline
I see no pics
Old 02-14-2020, 05:33 PM
I need a email to send pics . Thanks .
Old 03-01-2020, 08:59 PM
XXXXXXXXXXXXXXXXXXXXX BUMP XXXXXXXXXXXXXXXXXXXXX
Old 03-05-2020, 04:15 PM
F ROCK's Avatar
F ROCK F ROCK is offline
I bought a real nice set of #16 heads from Bober; packaged/shipped real well.
This is a great deal. I just paid $6000 for a similar, slightly lesser build, including the block and heads.
Old 03-13-2020, 07:04 PM
Thanks F ROCK !!!!!
Old 03-16-2020, 08:36 PM
cortcomp cortcomp is offline
Just sent a PM. Thanks!
Old 03-21-2020, 03:38 PM
SOLD
