When I originally saw this post, I wasn't near my car and did not recall that the rivets were actually outside the VIN 'window' and aft of the opening.
My dash pad has been recovered at some point by an old school upholsterer. It actually has stitched seams...so it may have been a little overstuffed and may not push forward as far as an original...so you can see my rivets but just barely.
Greg Reid Palmetto, Georgia |
Rosette portion is visible from the top side on my 68. Hard to believe they could be installed from the bottom ... aren't they blind rivets? The "stem" would be sticking up on the top if they were installed from the bottom.
Mine is still completely apart, I'll try to get photos above and below today. |
Here are 2 pictures from different project GTOs I own, both with dash pad removed ( you can clearly see where dash pad boundary is).
My guess is that, regardless of guidance at a give plant, the assembly worker did what was most expedient for them...
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
Don't forget that many cars had moisture issues at the base of the windshield where the metal dash meets the glass. I have seen more than a few cars who had repairs performed with the windshield out and then the top of the dash sprayed when done. Some do it "right" and others perform what they think "looks good". These are not always the same.
I would bet the car is as stated, just having had dash repair and repaint. Good luck!
Look at that, the stems are sticking up. Obvious installed from below. Probably depended on if "Joe" happened to be under the dash at the time ... "Bob" hands him the rivet gun and says ''Stick that on there for me Joe"
I wonder at what point on the assembly line the tags were added, at the body plant before it was mated to the chassis? Considering that some VINs are stamped on the firewall, that would mean they knew what body was going where way before it was mated with the chassis ... so I guess the VIN tag could actually be added when the upper dash panel was stamped, before it was even welded to rest of the body. |
To avoid any future confusion on which posts were made in which thread, I merged the two discussions on this topic.
The Following 3 Users Say Thank You to Stuart For This Useful Post: | ||
I think it safe to say most of the time the rivets are covered by the dash pad. Good point about rivets not being inside the "window". Here is a picture of my 68 Tempest Custom VIN tag. This car has 49,000 original miles.
Here's what may have caused some confusion for me. These 69 GTO VIN tags have rivets in a different and more noticeable place.
I recall having the rivet discussion in the past. My recollection is that the majority of the plants installed the rivets "down" (with the rosette portion on top) but that there was one plant that did it in the opposite directions for some reason (rosette on the bottom).
Perhaps in their process the windshield glass was already installed, forcing them to do it in a different way. In any case, I would not expect variation in the way it was done within the same plant. Quote:
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Everyone thanks for the info. I learned some new things. I made an offer on the car in question but was not accepted. However I am better prepared to make the next purchase!
The Following User Says Thank You to Mcronk For This Useful Post: | ||
