Old 01-25-2020, 04:39 PM
leeklm's Avatar
leeklm leeklm is offline
Default Door edge moldings?
Picked up some after market moldings. Any tricks to installing without boogering up the new paint?
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 01-25-2020, 06:30 PM
What brand? What type (style)?
Old 01-25-2020, 09:11 PM
leeklm's Avatar
These stainless pieces from Corvex...
Old 01-25-2020, 09:52 PM
That is the one I thought it was. Those will chip the paint off the door's edge.
I take a paint stick, sand the thickness to that of the door's edge, round off the end and tap it into the guard from one end to the other a little at a time to spread it open. Also, run your finger along the edges to check for stamping burrs that can scratch the paint. Test fit onto the door. You want it snug to slightly loose as to not damage the paint. Take clear silicone and place a very thin bead at the base of the groove of the guard. Reinstall and hand press it on from top to bottom until fully seated.
I have done them this way since the 80's and never chipped the paint.
Old 01-25-2020, 10:26 PM
leeklm's Avatar
Thanks, I will give that a try
Old 01-25-2020, 10:47 PM
Its a little time consuming but it works well and won't "F" up the paint. Also, place the guard on a 2x4 to protect the outside and absorb the impact.
Old 01-26-2020, 08:15 PM
leeklm's Avatar
Worked like a charm! Here are a couple of snap shots...
Old 01-26-2020, 09:52 PM
Old 01-27-2020, 09:10 PM
Flynbye's Avatar
Flynbye Flynbye is online now
Looking good, Lee!
Old 01-29-2020, 12:07 AM
leeklm's Avatar
Originally Posted by Flynbye View Post
Looking good, Lee!
Thank you for the help in sourcing the paint!
Old 01-29-2020, 09:56 AM
68tpls400 68tpls400 is offline
That was the easy part. Just run down to Bloomington and grab a sample!
Old 01-29-2020, 12:57 PM
leeklm's Avatar
But with great customer service!
