Old 01-27-2020, 12:24 PM
leeklm's Avatar
leeklm leeklm is offline
Default Installing trunk lid letters?
The trunk lid that came with my 68 is from a 69, so of course does not have the factory holes for mounting the PONTIAC letters.
I have a template from a 68 lid marking the hole locations, but prefer not to start drilling if I can avoid it. Has anyone tried buzzing off the pegs on backside of letters and gluing them on?
If yes, what did you use? I have some 3M 2 part clear seam sealer i thought might work well, assuming I can keep the stuff from oozing out the edges when pressed in place.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 01-29-2020, 04:30 PM
bascom123 bascom123 is offline
Send a message via MSN to bascom123
why not use 3M emblem double sided tape?
1969 Pontiac Firebird 400 - Candy Green
1977 Pontiac Trans Am 400 W72 - Black
Old 01-29-2020, 04:35 PM
That will raise the letters enough to be very noticable. The only good way is the proper way.
Old 01-29-2020, 07:45 PM
gtobird's Avatar
gtobird gtobird is offline
Hey, before you go ahead and drill the holes, be aware that one of the letters (I think it was the "I") had pegs that weren't a good match for the holes that were originally drilled in OEM trunk lids. The letter comes out tilted a bit. I'm not sure if that occurred only on some factory lids or all of them. I have two of them and both lids have that issue. If you do decide to drill the holes, you might want to correct the placement of the holes for that letter before you start drilling.
Old Joe
Old 01-30-2020, 09:26 AM
leeklm's Avatar
Thanks for the note. Another Pontiac guy mentioned that one of the letters came tilted from the factory. Was your factory letter tilted?
Old 01-30-2020, 10:00 AM
68tpls400 68tpls400 is offline
I think all of mine have the tilted letter. I do not remember if it was the 'I' or a different letter. I would have to look when the weather is a bit nicer.
Old 01-30-2020, 10:24 AM
leeklm's Avatar
Forecast high of 40 on Sunday, get that convertible out in the sun!!
Old 01-30-2020, 10:38 AM
Don't forget the pictures.
Old 01-30-2020, 11:12 AM
From this shot, looks like the 'T' to me. I'll keep looking.
Old 01-30-2020, 11:16 AM
Yep, looks like the 'T'.
Can't wait for summer!
Name:	Big boy's toys 005.jpg
ID:	530535   Click image for larger version
Name:	Big boy's toys 003.jpg
Old 01-30-2020, 11:20 AM
leeklm's Avatar
I just confirmed with our friend that the "T" is normally tilted a little.
Old 01-30-2020, 11:23 AM
leeklm's Avatar
Looks like a fast purple 68 would complete that collection!!
Old 01-30-2020, 11:24 AM
Well, if you weren't so slow to the party, that could have happened!
Old 01-30-2020, 12:13 PM
Keith Seymore's Avatar
Old Joe
My recollection is that the pegs did not fully error proof the "T" and the "I" either.
I've seen a couple original cars that were "PONITAC"s.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 01-30-2020, 01:02 PM
1stGenFB 1stGenFB is offline
Mine has the letter T tilted to the left
Old 01-30-2020, 01:35 PM
So this begs to ask..... Do you swing to the left or to the right? LOL
Old 01-30-2020, 01:44 PM
Consistently inconsistent I guess. Good old GM...
Old 02-12-2020, 05:49 PM
leeklm's Avatar
Got'r done... the letter pegs were not long enough for the retaining nuts after going through both layers of trunk skin. Instead of trying to cut or drill through the under layer (like factory), I mixed up some epoxy and coated the positioning pegs. I figured this would also seal up the pilot holes to prevent water seeping in. A bit of screwing around, but it worked well!
