Old 04-05-2020, 08:08 PM
JAL71TA JAL71TA is offline
Default power door locks issue
I have a 71 TA with factory power door locks. Manually they work fine with either hand or key. Issue is the door locks only work intermittently using the dash switch. I've tried WD 40 on the switch and locks and its still not functioning properly. Any ideas??
Jim
Old 04-06-2020, 12:08 AM
Have you tried running voltage directly to the solenoids? If they don't work then replace the solenoids.
Old 04-06-2020, 08:03 AM
I have not done that yet, thanks for the reply.
