Old 01-16-2021, 09:22 AM
firechicken's Avatar
firechicken firechicken is offline
Wow, now that's a winter upgrade!
  #142
Old 01-16-2021, 11:08 AM
GTOGEORGE's Avatar
Originally Posted by 69Goat1 View Post
First time I have ever used something other than a factory block and crank...IAIIA, 12.5:1, wide ports, 284 solid roller, Gutsram converted to blower top, Ed Pink 8-71 newly rebuilt and fully stripped, Enderle Alcohol injection...going in my Green 69 GTO that also got a lot of work done like rack, mini tub, 12 point cage, complete TRZ control arms front and rear and coil overs at all 4 corners, wilwood brakes, tube core support, tube engine crossmember and tube trans mount, front and mid plate...still all steel except front bumper and hood and all factory glass...
Sent from my iPad using Tapatalk
Pro Street!
GTO George
  #143
Old 06-29-2022, 01:14 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
I haven't posted any updates in a while, but I have slowly chipping away at this thing and it is almost ready. I got my fiberglass bumper back and hung, finished up the radiator and trans cooler mounts, along with my removable tool tray, made new cooler lines (not pictured), got the car running first on gas with the old edelbrock carb then on methanol with the KJP carb. got the housing squared and the pinion angle all set. Hoping to hit the track July 9&10 if all goes well
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
The Following User Says Thank You to adam woodmancy For This Useful Post:
  #144
Old 06-29-2022, 11:13 PM
blueghoast's Avatar
I've been wanting to do that with a wenzler. On engine masters it made
100 more HP and no inter cooler. Good luck with it.
GT
  #145
Old 06-30-2022, 07:01 AM
mysticmissle's Avatar
looks really nice Adam.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #146
Old 10-03-2023, 04:27 PM
Finally got the car on some scales. I was pretty happy with it, and actually 100lbs or so lighter than i expected.
1972 Pontiac LeMans
Thanks to
